When i was running freenas 8x (x64) I was getting pretty good performance.
once the drives would spin up from sleep. file lists or copy's were near instant. and I would get about 100-130 mb/s
I upgraded to 9x (x64) and Now when I go to click on a directory, there is a noticeable pause before the directory is displayed. even if you then go to another folder right away, there is still a pause before it is shows.
my transfer speeds are now around 80-86 mb /s
So something has change and I'm not sure where to start looking to figure out what I can do to reclaim that 8x performance.
Note: these are cifs shares. on windows boxes.
Any ideas on where i should start looking? Thanks
Edit: here are my cifs settings.
read raw = yes
write raw = yes
max xmit = 65536
getwd cache = yes
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_KEEPALIVE SO_RCVBUF=98304 SO_SNDBUF=98304
read raw = yes
write raw = yes
max xmit = 65536
getwd cache = yes
