Slow reads, normal writes with CIFS
mooseracing
Instead of filling someone else's thread here is my mess:
I've tried a Core2Duo 3Ghz, 4GB RAM, 6 - 1TB Samsung drives in ZFS RAID Z1. I also did this same setup in a older P4 but with 3GB RAM with the same results. Right now I get from 60-100MB/s write speeds and about 3MB/s read. Slightly backwards if I was expecting these results.
dd shows ~165 MB/s Writes - P4 3GB
~200 MB/s Reads - P4
~190MB/s Writes - C2D 4GB
~270 Reads
My writes went up using these settings from another thread:
vfs.zfs.arc_max	1073741824	Generated by autotune
vm.kmem_size_max	1719738496	Generated by autotune
vm.kmem_size	1375790796	Generated by autotune
kern.ipc.nmbclusters	15000	Generated by autotune
kern.ipc.maxsockbuf	67108864
kern.ipc.somaxconn	16384
net.inet.tcp.inflight.enable	0
net.inet.tcp.recvbuf_auto	1
net.inet.tcp.recvbuf_inc	524288
net.inet.tcp.recvspace	131072
net.inet.tcp.rfc1323	1
net.inet.tcp.sendbuf_auto	1
net.inet.tcp.sendbuf_inc	65536
net.inet.tcp.sendspace	131072
net.inet.udp.recvspace	65536
net.inet.udp.maxdgram	57344
net.local.stream.recvspace	65536
net.local.stream.sendspace	65536
net.inet.tcp.recvbuf_max	16777216
net.inet.tcp.sendbuf_max	16777216
And in CIFS
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_KEEPALIVE SO_RCVBUF=131072 SO_SNDBUF=131072 IPTOS_THROUGHPUT
read raw = yes
write raw = yes
oplocks = yes
max xmit = 131072
write cache size = 131072
Sendfiles and AIO is disabled currently.
The other thing that seems odd, when doing transfers writes use about 30% of the CPU - samba, with reads, its tenths of a %. The machine also has about 2.5GB's free of RAM during transfers.
mooseracing
I setup an iSCSI target as I thought maybe I could work around the issue, but the same problem happens. Great write speeds, horrible reads.
noee
Look here for potential help. Using just UFS with Samsung 1TB drives, I can saturate the GbE with these settings (8.3.1Alpha).
mooseracing
I already had most of those, I changed my values to match and added to sysctls, still a whopping 2.5MB/s reads. Samba is showing no utilization.
I also tried creating it via UFS, same issue.
mooseracing
I also just added the variable to specify smb2, it's working good on my other servers but one is still reading slow. Wondering if I need to restart it to flush any information it is storing about the Freenas box.
