First log I pulled from yesterday afternoon. You will see references to the onboard disk controllers (Marvell and Intel) which I do not use.
Mar 8 13:19:10 freenas newsyslog[2001]: logfile first created
Mar 8 13:19:10 freenas syslogd: kernel boot file is /boot/kernel/kernel
Mar 8 13:19:10 freenas kernel: Copyright (c) 1992-2012 The FreeBSD Project.
Mar 8 13:19:10 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Mar 8 13:19:10 freenas kernel: The Regents of the University of California. All rights reserved.
Mar 8 13:19:10 freenas kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Mar 8 13:19:10 freenas kernel: FreeBSD 8.3-RELEASE-p5 #2 r244158M: Wed Dec 12 10:04:42 PST 2012
Mar 8 13:19:10 freenas kernel: root@build.ixsystems.com:/home/jpaetzel/8.3.0/os-base/amd64/usr/home/jpaetzel/8.3.0/FreeBSD/src/sys/FREENAS.amd64 amd64
Mar 8 13:19:10 freenas kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Mar 8 13:19:10 freenas kernel: CPU: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz (2831.63-MHz K8-class CPU)
Mar 8 13:19:10 freenas kernel: Origin = "GenuineIntel" Id = 0x106a5 Family = 6 Model = 1a Stepping = 5
Mar 8 13:19:10 freenas kernel: Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Mar 8 13:19:10 freenas kernel: Features2=0x98e3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,POPCNT>
Mar 8 13:19:10 freenas kernel: AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
Mar 8 13:19:10 freenas kernel: AMD Features2=0x1<LAHF>
Mar 8 13:19:10 freenas kernel: TSC: P-state invariant
Mar 8 13:19:10 freenas kernel: real memory = 12884901888 (12288 MB)
Mar 8 13:19:10 freenas kernel: avail memory = 12370894848 (11797 MB)
Mar 8 13:19:10 freenas kernel: ACPI APIC Table: <022410 APIC1223>
Mar 8 13:19:10 freenas kernel: FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
Mar 8 13:19:10 freenas kernel: FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads
Mar 8 13:19:10 freenas kernel: cpu0 (BSP): APIC ID: 0
Mar 8 13:19:10 freenas kernel: cpu1 (AP): APIC ID: 1
Mar 8 13:19:10 freenas kernel: cpu2 (AP): APIC ID: 2
Mar 8 13:19:10 freenas kernel: cpu3 (AP): APIC ID: 3
Mar 8 13:19:10 freenas kernel: cpu4 (AP): APIC ID: 4
Mar 8 13:19:10 freenas kernel: cpu5 (AP): APIC ID: 5
Mar 8 13:19:10 freenas kernel: cpu6 (AP): APIC ID: 6
Mar 8 13:19:10 freenas kernel: cpu7 (AP): APIC ID: 7
Mar 8 13:19:10 freenas kernel: WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Mar 8 13:19:10 freenas kernel: ioapic0 <Version 2.0> irqs 0-23 on motherboard
Mar 8 13:19:10 freenas kernel: ioapic1 <Version 2.0> irqs 24-47 on motherboard
Mar 8 13:19:10 freenas kernel: kbd1 at kbdmux0
Mar 8 13:19:10 freenas kernel: hpt27xx: RocketRAID 27xx controller driver v1.0 (Dec 12 2012 10:04:31)
Mar 8 13:19:10 freenas kernel: cryptosoft0: <software crypto> on motherboard
Mar 8 13:19:10 freenas kernel: aesni0: No AESNI support.
Mar 8 13:19:10 freenas kernel: acpi0: <022410 RSDT1223> on motherboard
Mar 8 13:19:10 freenas kernel: acpi0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: acpi0: Power Button (fixed)
Mar 8 13:19:10 freenas kernel: acpi0: reservation of fee00000, 1000 (3) failed
Mar 8 13:19:10 freenas kernel: acpi0: reservation of 0, a0000 (3) failed
Mar 8 13:19:10 freenas kernel: acpi0: reservation of 100000, bff00000 (3) failed
Mar 8 13:19:10 freenas kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
Mar 8 13:19:10 freenas kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
Mar 8 13:19:10 freenas kernel: cpu0: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: cpu1: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: cpu2: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: cpu3: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: cpu4: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: cpu5: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: cpu6: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: cpu7: <ACPI CPU> on acpi0
Mar 8 13:19:10 freenas kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Mar 8 13:19:10 freenas kernel: pci0: <ACPI PCI bus> on pcib0
Mar 8 13:19:10 freenas kernel: pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
Mar 8 13:19:10 freenas kernel: pci1: <ACPI PCI bus> on pcib1
Mar 8 13:19:10 freenas kernel: atapci0: <Marvell ATA controller> port 0x8c00-0x8c07,0x8880-0x8883,0x8800-0x8807,0x8480-0x8483,0x8400-0x840f mem 0xf8dff800-0xf8dfffff irq 28 at device 0.0 on pci1
Mar 8 13:19:10 freenas kernel: atapci0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: ata2: <ATA channel> at channel 0 on atapci0
Mar 8 13:19:10 freenas kernel: ata2: [ITHREAD]
Mar 8 13:19:10 freenas kernel: ata3: <ATA channel> at channel 1 on atapci0
Mar 8 13:19:10 freenas kernel: ata3: [ITHREAD]
Mar 8 13:19:10 freenas kernel: pcib2: <ACPI PCI-PCI bridge> at device 2.0 on pci0
Mar 8 13:19:10 freenas kernel: pci2: <ACPI PCI bus> on pcib2
Mar 8 13:19:10 freenas kernel: pci2: <serial bus, USB> at device 0.0 (no driver attached)
Mar 8 13:19:10 freenas kernel: pcib3: <ACPI PCI-PCI bridge> at device 3.0 on pci0
Mar 8 13:19:10 freenas kernel: pci3: <ACPI PCI bus> on pcib3
Mar 8 13:19:10 freenas kernel: pcib4: <PCI-PCI bridge> irq 24 at device 0.0 on pci3
Mar 8 13:19:10 freenas kernel: pci4: <PCI bus> on pcib4
Mar 8 13:19:10 freenas kernel: siis0: <SiI3124 SATA controller> port 0x9c00-0x9c0f mem 0xf8fffc00-0xf8fffc7f,0xf8ff0000-0xf8ff7fff irq 24 at device 4.0 on pci4
Mar 8 13:19:10 freenas kernel: siis0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch0: <SIIS channel> at channel 0 on siis0
Mar 8 13:19:10 freenas kernel: siisch0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch1: <SIIS channel> at channel 1 on siis0
Mar 8 13:19:10 freenas kernel: siisch1: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch2: <SIIS channel> at channel 2 on siis0
Mar 8 13:19:10 freenas kernel: siisch2: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch3: <SIIS channel> at channel 3 on siis0
Mar 8 13:19:10 freenas kernel: siisch3: [ITHREAD]
Mar 8 13:19:10 freenas kernel: pcib5: <ACPI PCI-PCI bridge> at device 7.0 on pci0
Mar 8 13:19:10 freenas kernel: pci5: <ACPI PCI bus> on pcib5
Mar 8 13:19:10 freenas kernel: vgapci0: <VGA-compatible display> mem 0xfa000000-0xfaffffff,0xd0000000-0xdfffffff,0xf9000000-0xf9ffffff irq 30 at device 0.0 on pci5
Mar 8 13:19:10 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.0 (no driver attached)
Mar 8 13:19:10 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.1 (no driver attached)
Mar 8 13:19:10 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.2 (no driver attached)
Mar 8 13:19:10 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.3 (no driver attached)
Mar 8 13:19:10 freenas kernel: uhci0: <Intel 82801JI (ICH10) USB controller USB-D> port 0x7800-0x781f irq 16 at device 26.0 on pci0
Mar 8 13:19:10 freenas kernel: uhci0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus0: <Intel 82801JI (ICH10) USB controller USB-D> on uhci0
Mar 8 13:19:10 freenas kernel: uhci1: <Intel 82801JI (ICH10) USB controller USB-E> port 0x7880-0x789f irq 21 at device 26.1 on pci0
Mar 8 13:19:10 freenas kernel: uhci1: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus1: <Intel 82801JI (ICH10) USB controller USB-E> on uhci1
Mar 8 13:19:10 freenas kernel: uhci2: <Intel 82801JI (ICH10) USB controller USB-F> port 0x7c00-0x7c1f irq 19 at device 26.2 on pci0
Mar 8 13:19:10 freenas kernel: uhci2: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus2: <Intel 82801JI (ICH10) USB controller USB-F> on uhci2
Mar 8 13:19:10 freenas kernel: ehci0: <Intel 82801JI (ICH10) USB 2.0 controller USB-B> mem 0xf8cff000-0xf8cff3ff irq 18 at device 26.7 on pci0
Mar 8 13:19:10 freenas kernel: ehci0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus3: EHCI version 1.0
Mar 8 13:19:10 freenas kernel: usbus3: <Intel 82801JI (ICH10) USB 2.0 controller USB-B> on ehci0
Mar 8 13:19:10 freenas kernel: pci0: <multimedia, HDA> at device 27.0 (no driver attached)
Mar 8 13:19:10 freenas kernel: pcib6: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
Mar 8 13:19:10 freenas kernel: pci11: <ACPI PCI bus> on pcib6
Mar 8 13:19:10 freenas kernel: pcib7: <ACPI PCI-PCI bridge> irq 16 at device 28.1 on pci0
Mar 8 13:19:10 freenas kernel: pci9: <ACPI PCI bus> on pcib7
Mar 8 13:19:10 freenas kernel: pcib8: <PCI-PCI bridge> irq 17 at device 0.0 on pci9
Mar 8 13:19:10 freenas kernel: pci10: <PCI bus> on pcib8
Mar 8 13:19:10 freenas kernel: siis1: <SiI3124 SATA controller> port 0xdc00-0xdc0f mem 0xfbdffc00-0xfbdffc7f,0xfbdf0000-0xfbdf7fff irq 17 at device 4.0 on pci10
Mar 8 13:19:10 freenas kernel: siis1: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch4: <SIIS channel> at channel 0 on siis1
Mar 8 13:19:10 freenas kernel: siisch4: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch5: <SIIS channel> at channel 1 on siis1
Mar 8 13:19:10 freenas kernel: siisch5: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch6: <SIIS channel> at channel 2 on siis1
Mar 8 13:19:10 freenas kernel: siisch6: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch7: <SIIS channel> at channel 3 on siis1
Mar 8 13:19:10 freenas kernel: siisch7: [ITHREAD]
Mar 8 13:19:10 freenas kernel: pcib9: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
Mar 8 13:19:10 freenas kernel: pci8: <ACPI PCI bus> on pcib9
Mar 8 13:19:10 freenas kernel: mskc0: <Marvell Yukon 88E8056 Gigabit Ethernet> port 0xc800-0xc8ff mem 0xfbcfc000-0xfbcfffff irq 18 at device 0.0 on pci8
Mar 8 13:19:10 freenas kernel: msk0: <Marvell Technology Group Ltd. Yukon EC Ultra Id 0xb4 Rev 0x03> on mskc0
Mar 8 13:19:10 freenas kernel: msk0: Ethernet address: 48:5b:39:45:08:8a
Mar 8 13:19:10 freenas kernel: miibus0: <MII bus> on msk0
Mar 8 13:19:10 freenas kernel: e1000phy0: <Marvell 88E1149 Gigabit PHY> PHY 0 on miibus0
Mar 8 13:19:10 freenas kernel: e1000phy0: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Mar 8 13:19:10 freenas kernel: mskc0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: pcib10: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
Mar 8 13:19:10 freenas kernel: pci7: <ACPI PCI bus> on pcib10
Mar 8 13:19:10 freenas kernel: siis2: <SiI3132 SATA controller> port 0xbc00-0xbc7f mem 0xfbbffc00-0xfbbffc7f,0xfbbf8000-0xfbbfbfff irq 16 at device 0.0 on pci7
Mar 8 13:19:10 freenas kernel: siis2: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch8: <SIIS channel> at channel 0 on siis2
Mar 8 13:19:10 freenas kernel: siisch8: [ITHREAD]
Mar 8 13:19:10 freenas kernel: siisch9: <SIIS channel> at channel 1 on siis2
Mar 8 13:19:10 freenas kernel: siisch9: [ITHREAD]
Mar 8 13:19:10 freenas kernel: pcib11: <ACPI PCI-PCI bridge> irq 16 at device 28.5 on pci0
Mar 8 13:19:10 freenas kernel: pci6: <ACPI PCI bus> on pcib11
Mar 8 13:19:10 freenas kernel: mskc1: <Marvell Yukon 88E8056 Gigabit Ethernet> port 0xa800-0xa8ff mem 0xfbafc000-0xfbafffff irq 17 at device 0.0 on pci6
Mar 8 13:19:10 freenas kernel: msk1: <Marvell Technology Group Ltd. Yukon EC Ultra Id 0xb4 Rev 0x03> on mskc1
Mar 8 13:19:10 freenas kernel: msk1: Ethernet address: 48:5b:39:45:01:00
Mar 8 13:19:10 freenas kernel: miibus1: <MII bus> on msk1
Mar 8 13:19:10 freenas kernel: e1000phy1: <Marvell 88E1149 Gigabit PHY> PHY 0 on miibus1
Mar 8 13:19:10 freenas kernel: e1000phy1: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Mar 8 13:19:10 freenas kernel: mskc1: [ITHREAD]
Mar 8 13:19:10 freenas kernel: uhci3: <Intel 82801JI (ICH10) USB controller USB-A> port 0x7080-0x709f irq 23 at device 29.0 on pci0
Mar 8 13:19:10 freenas kernel: uhci3: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus4: <Intel 82801JI (ICH10) USB controller USB-A> on uhci3
Mar 8 13:19:10 freenas kernel: uhci4: <Intel 82801JI (ICH10) USB controller USB-B> port 0x7400-0x741f irq 19 at device 29.1 on pci0
Mar 8 13:19:10 freenas kernel: uhci4: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus5: <Intel 82801JI (ICH10) USB controller USB-B> on uhci4
Mar 8 13:19:10 freenas kernel: uhci5: <Intel 82801JI (ICH10) USB controller USB-C> port 0x7480-0x749f irq 18 at device 29.2 on pci0
Mar 8 13:19:10 freenas kernel: uhci5: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus6: <Intel 82801JI (ICH10) USB controller USB-C> on uhci5
Mar 8 13:19:10 freenas kernel: ehci1: <Intel 82801JI (ICH10) USB 2.0 controller USB-A> mem 0xf8cfe000-0xf8cfe3ff irq 23 at device 29.7 on pci0
Mar 8 13:19:10 freenas kernel: ehci1: [ITHREAD]
Mar 8 13:19:10 freenas kernel: usbus7: EHCI version 1.0
Mar 8 13:19:10 freenas kernel: usbus7: <Intel 82801JI (ICH10) USB 2.0 controller USB-A> on ehci1
Mar 8 13:19:10 freenas kernel: pcib12: <ACPI PCI-PCI bridge> at device 30.0 on pci0
Mar 8 13:19:10 freenas kernel: pci12: <ACPI PCI bus> on pcib12
Mar 8 13:19:10 freenas kernel: fwohci0: <VIA Fire II (VT6306)> port 0xec00-0xec7f mem 0xfbeff000-0xfbeff7ff irq 18 at device 2.0 on pci12
Mar 8 13:19:10 freenas kernel: fwohci0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: fwohci0: OHCI version 1.10 (ROM=1)
Mar 8 13:19:10 freenas kernel: fwohci0: No. of Isochronous channels is 4.
Mar 8 13:19:10 freenas kernel: fwohci0: EUI64 00:1e:8c:00:00:d5:50:f3
Mar 8 13:19:10 freenas kernel: fwohci0: Phy 1394a available S400, 2 ports.
Mar 8 13:19:10 freenas kernel: fwohci0: Link S400, max_rec 2048 bytes.
Mar 8 13:19:10 freenas kernel: firewire0: <IEEE1394(FireWire) bus> on fwohci0
Mar 8 13:19:10 freenas kernel: sbp0: <SBP-2/SCSI over FireWire> on firewire0
Mar 8 13:19:10 freenas kernel: fwohci0: Initiate bus reset
Mar 8 13:19:10 freenas kernel: fwohci0: fwohci_intr_core: BUS reset
Mar 8 13:19:10 freenas kernel: fwohci0: fwohci_intr_core: node_id=0x00000000, SelfID Count=1, CYCLEMASTER mode
Mar 8 13:19:10 freenas kernel: isab0: <PCI-ISA bridge> at device 31.0 on pci0
Mar 8 13:19:10 freenas kernel: isa0: <ISA bus> on isab0
Mar 8 13:19:10 freenas kernel: atapci1: <Intel ICH10 SATA300 controller> port 0x6000-0x6007,0x5c00-0x5c03,0x5880-0x5887,0x5800-0x5803,0x5480-0x548f,0x5400-0x540f irq 20 at device 31.2 on pci0
Mar 8 13:19:10 freenas kernel: atapci1: [ITHREAD]
Mar 8 13:19:10 freenas kernel: ata4: <ATA channel> at channel 0 on atapci1
Mar 8 13:19:10 freenas kernel: ata4: [ITHREAD]
Mar 8 13:19:10 freenas kernel: ata5: <ATA channel> at channel 1 on atapci1
Mar 8 13:19:10 freenas kernel: ata5: [ITHREAD]
Mar 8 13:19:10 freenas kernel: pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
Mar 8 13:19:10 freenas kernel: atapci2: <Intel ICH10 SATA300 controller> port 0x7000-0x7007,0x6c00-0x6c03,0x6880-0x6887,0x6800-0x6803,0x6480-0x648f,0x6400-0x640f irq 20 at device 31.5 on pci0
Mar 8 13:19:10 freenas kernel: atapci2: [ITHREAD]
Mar 8 13:19:10 freenas kernel: ata6: <ATA channel> at channel 0 on atapci2
Mar 8 13:19:10 freenas kernel: ata6: [ITHREAD]
Mar 8 13:19:10 freenas kernel: ata7: <ATA channel> at channel 1 on atapci2
Mar 8 13:19:10 freenas kernel: ata7: [ITHREAD]
Mar 8 13:19:10 freenas kernel: acpi_button0: <Power Button> on acpi0
Mar 8 13:19:10 freenas kernel: atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Mar 8 13:19:10 freenas kernel: acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Mar 8 13:19:10 freenas kernel: Timecounter "HPET" frequency 14318180 Hz quality 900
Mar 8 13:19:10 freenas kernel: qpi0: <QPI system bus> on motherboard
Mar 8 13:19:10 freenas kernel: pcib13: <QPI Host-PCI bridge> pcibus 255 on qpi0
Mar 8 13:19:10 freenas kernel: pci255: <PCI bus> on pcib13
Mar 8 13:19:10 freenas kernel: sc0: <System console> at flags 0x100 on isa0
Mar 8 13:19:10 freenas kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Mar 8 13:19:10 freenas kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Mar 8 13:19:10 freenas kernel: atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
Mar 8 13:19:10 freenas kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Mar 8 13:19:10 freenas kernel: kbd0 at atkbd0
Mar 8 13:19:10 freenas kernel: atkbd0: [GIANT-LOCKED]
Mar 8 13:19:10 freenas kernel: atkbd0: [ITHREAD]
Mar 8 13:19:10 freenas kernel: ppc0: cannot reserve I/O port range
Mar 8 13:19:10 freenas kernel: coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Mar 8 13:19:10 freenas kernel: est0: <Enhanced SpeedStep Frequency Control> on cpu0
Mar 8 13:19:10 freenas kernel: p4tcc0: <CPU Frequency Thermal Control> on cpu0
Mar 8 13:19:10 freenas kernel: coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Mar 8 13:19:10 freenas kernel: est1: <Enhanced SpeedStep Frequency Control> on cpu1
Mar 8 13:19:10 freenas kernel: p4tcc1: <CPU Frequency Thermal Control> on cpu1
Mar 8 13:19:10 freenas kernel: coretemp2: <CPU On-Die Thermal Sensors> on cpu2
Mar 8 13:19:10 freenas kernel: est2: <Enhanced SpeedStep Frequency Control> on cpu2
Mar 8 13:19:10 freenas kernel: p4tcc2: <CPU Frequency Thermal Control> on cpu2
Mar 8 13:19:10 freenas kernel: coretemp3: <CPU On-Die Thermal Sensors> on cpu3
Mar 8 13:19:10 freenas kernel: est3: <Enhanced SpeedStep Frequency Control> on cpu3
Mar 8 13:19:10 freenas kernel: p4tcc3: <CPU Frequency Thermal Control> on cpu3
Mar 8 13:19:10 freenas kernel: coretemp4: <CPU On-Die Thermal Sensors> on cpu4
Mar 8 13:19:10 freenas kernel: est4: <Enhanced SpeedStep Frequency Control> on cpu4
Mar 8 13:19:10 freenas kernel: p4tcc4: <CPU Frequency Thermal Control> on cpu4
Mar 8 13:19:10 freenas kernel: coretemp5: <CPU On-Die Thermal Sensors> on cpu5
Mar 8 13:19:10 freenas kernel: est5: <Enhanced SpeedStep Frequency Control> on cpu5
Mar 8 13:19:10 freenas kernel: p4tcc5: <CPU Frequency Thermal Control> on cpu5
Mar 8 13:19:10 freenas kernel: coretemp6: <CPU On-Die Thermal Sensors> on cpu6
Mar 8 13:19:10 freenas kernel: est6: <Enhanced SpeedStep Frequency Control> on cpu6
Mar 8 13:19:10 freenas kernel: p4tcc6: <CPU Frequency Thermal Control> on cpu6
Mar 8 13:19:10 freenas kernel: coretemp7: <CPU On-Die Thermal Sensors> on cpu7
Mar 8 13:19:10 freenas kernel: est7: <Enhanced SpeedStep Frequency Control> on cpu7
Mar 8 13:19:10 freenas kernel: p4tcc7: <CPU Frequency Thermal Control> on cpu7
Mar 8 13:19:10 freenas kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Mar 8 13:19:10 freenas kernel: Timecounters tick every 1.000 msec
Mar 8 13:19:10 freenas kernel: hpt27xx: no controller detected.
Mar 8 13:19:10 freenas kernel: firewire0: 1 nodes, maxhop <= 0 cable IRM irm(0) (me)
Mar 8 13:19:10 freenas kernel: firewire0: bus manager 0
Mar 8 13:19:10 freenas kernel: (noperiph:siisch4:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: (noperiph:siisch5:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: (noperiph:siisch6:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: (noperiph:siisch7:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: (noperiph:siisch8:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: (noperiph:siisch9:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: (noperiph:siisch0:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: (noperiph:siisch2:0:-1:-1): rescan already queued
Mar 8 13:19:10 freenas kernel: usbus0: 12Mbps Full Speed USB v1.0
Mar 8 13:19:10 freenas kernel: usbus1: 12Mbps Full Speed USB v1.0
Mar 8 13:19:10 freenas kernel: usbus2: 12Mbps Full Speed USB v1.0
Mar 8 13:19:10 freenas kernel: usbus3: 480Mbps High Speed USB v2.0
Mar 8 13:19:10 freenas kernel: usbus4: 12Mbps Full Speed USB v1.0
Mar 8 13:19:10 freenas kernel: usbus5: 12Mbps Full Speed USB v1.0
Mar 8 13:19:10 freenas kernel: usbus6: 12Mbps Full Speed USB v1.0
Mar 8 13:19:10 freenas kernel: usbus7: 480Mbps High Speed USB v2.0
Mar 8 13:19:10 freenas kernel: ugen0.1: <Intel> at usbus0
Mar 8 13:19:10 freenas kernel: uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
Mar 8 13:19:10 freenas kernel: ugen1.1: <Intel> at usbus1
Mar 8 13:19:10 freenas kernel: uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
Mar 8 13:19:10 freenas kernel: ugen2.1: <Intel> at usbus2
Mar 8 13:19:10 freenas kernel: uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
Mar 8 13:19:10 freenas kernel: ugen3.1: <Intel> at usbus3
Mar 8 13:19:10 freenas kernel: uhub3: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
Mar 8 13:19:10 freenas kernel: ugen4.1: <Intel> at usbus4
Mar 8 13:19:10 freenas kernel: uhub4: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
Mar 8 13:19:10 freenas kernel: ugen5.1: <Intel> at usbus5
Mar 8 13:19:10 freenas kernel: uhub5: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
Mar 8 13:19:10 freenas kernel: ugen6.1: <Intel> at usbus6
Mar 8 13:19:10 freenas kernel: uhub6: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
Mar 8 13:19:10 freenas kernel: ugen7.1: <Intel> at usbus7
Mar 8 13:19:10 freenas kernel: uhub7: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus7
Mar 8 13:19:10 freenas kernel: uhub0: 2 ports with 2 removable, self powered
Mar 8 13:19:10 freenas kernel: uhub1: 2 ports with 2 removable, self powered
Mar 8 13:19:10 freenas kernel: uhub2: 2 ports with 2 removable, self powered
Mar 8 13:19:10 freenas kernel: uhub4: 2 ports with 2 removable, self powered
Mar 8 13:19:10 freenas kernel: uhub5: 2 ports with 2 removable, self powered
Mar 8 13:19:10 freenas kernel: uhub6: 2 ports with 2 removable, self powered
Mar 8 13:19:10 freenas kernel: uhub3: 6 ports with 6 removable, self powered
Mar 8 13:19:10 freenas kernel: uhub7: 6 ports with 6 removable, self powered
Mar 8 13:19:10 freenas kernel: ugen3.2: <HP> at usbus3
Mar 8 13:19:10 freenas kernel: umass0: <HP USB Flash Drive, class 0/0, rev 2.00/1.00, addr 2> on usbus3
Mar 8 13:19:10 freenas kernel: pmp0 at siisch0 bus 0 scbus2 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp0: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp0: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp0: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: pmp1 at siisch2 bus 0 scbus4 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp1: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp1: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp1: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: pmp2 at siisch4 bus 0 scbus6 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp2: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp2: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp2: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: pmp3 at siisch5 bus 0 scbus7 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp3: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp3: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp3: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: pmp4 at siisch6 bus 0 scbus8 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp4: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp4: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp4: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: pmp5 at siisch7 bus 0 scbus9 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp5: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp5: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp5: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: pmp6 at siisch8 bus 0 scbus10 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp6: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp6: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp6: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: pmp7 at siisch9 bus 0 scbus11 target 15 lun 0
Mar 8 13:19:10 freenas kernel: pmp7: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:19:10 freenas kernel: pmp7: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: pmp7: 5 fan-out ports
Mar 8 13:19:10 freenas kernel: ada0 at siisch0 bus 0 scbus2 target 0 lun 0
Mar 8 13:19:10 freenas kernel: ada0: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada0: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada0: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada1 at siisch0 bus 0 scbus2 target 1 lun 0
Mar 8 13:19:10 freenas kernel: ada1: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada1: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada1: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada2 at siisch0 bus 0 scbus2 target 2 lun 0
Mar 8 13:19:10 freenas kernel: ada2: <WDC WD20EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
Mar 8 13:19:10 freenas kernel: ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada2: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada3 at siisch0 bus 0 scbus2 target 3 lun 0
Mar 8 13:19:10 freenas kernel: ada3: <WDC WD20EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
Mar 8 13:19:10 freenas kernel: ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada3: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada4 at siisch0 bus 0 scbus2 target 4 lun 0
Mar 8 13:19:10 freenas kernel: ada4: <WDC WD20EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
Mar 8 13:19:10 freenas kernel: ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada4: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada4: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada5 at siisch2 bus 0 scbus4 target 0 lun 0
Mar 8 13:19:10 freenas kernel: ada5: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada5: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada5: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada6 at siisch2 bus 0 scbus4 target 1 lun 0
Mar 8 13:19:10 freenas kernel: ada6: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada6: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada6: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada6: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada7 at siisch2 bus 0 scbus4 target 2 lun 0
Mar 8 13:19:10 freenas kernel: ada7: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada7: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada7: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada7: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada8 at siisch2 bus 0 scbus4 target 3 lun 0
Mar 8 13:19:10 freenas kernel: ada8: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada8: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada8: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada8: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada9 at siisch2 bus 0 scbus4 target 4 lun 0
Mar 8 13:19:10 freenas kernel: ada9: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada9: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada9: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada9: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada10 at siisch4 bus 0 scbus6 target 0 lun 0
Mar 8 13:19:10 freenas kernel: ada10: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada10: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada10: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada10: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: ada11 at siisch4 bus 0 scbus6 target 1 lun 0
Mar 8 13:19:10 freenas kernel: ada11: <ST31500341AS CC1H> ATA-8 SATA 2.x device
Mar 8 13:19:10 freenas kernel: ada11: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Mar 8 13:19:10 freenas kernel: ada11: Command Queueing enabled
Mar 8 13:19:10 freenas kernel: ada11: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Mar 8 13:19:10 freenas kernel: da0 at umass-sim0 bus 0 scbus17 target 0 lun 0
Mar 8 13:19:10 freenas kernel: da0: <hp USB FLASH DRIVE 0.00> Removable Direct Access SCSI-2 device
Mar 8 13:19:10 freenas kernel: da0: 40.000MB/s transfers
Mar 8 13:19:10 freenas kernel: da0: 3854MB (7892992 512 byte sectors: 255H 63S/T 491C)
Mar 8 13:19:10 freenas kernel: SMP: AP CPU #1 Launched!
Mar 8 13:19:10 freenas kernel: SMP: AP CPU #7 Launched!
Mar 8 13:19:10 freenas kernel: SMP: AP CPU #3 Launched!
Mar 8 13:19:10 freenas kernel: SMP: AP CPU #6 Launched!
Mar 8 13:19:10 freenas kernel: SMP: AP CPU #5 Launched!
Mar 8 13:19:10 freenas kernel: SMP: AP CPU #2 Launched!
Mar 8 13:19:10 freenas kernel: SMP: AP CPU #4 Launched!
Mar 8 13:19:10 freenas kernel: GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Mar 8 13:19:10 freenas kernel: GEOM: da0s2: geometry does not match label (16h,63s != 255h,63s).
Mar 8 13:19:10 freenas kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Mar 8 13:19:10 freenas kernel: ZFS filesystem version 5
Mar 8 13:19:10 freenas kernel: ZFS storage pool version 28
Mar 8 13:19:10 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Mar 8 13:19:11 freenas ntpd[2990]: ntpd 4.2.4p5-a (1)
Mar 8 13:19:13 freenas proftpd[3124]: 127.0.0.1 - ProFTPD 1.3.4a (maint) (built Wed Oct 31 2012 21:33:51 UTC) standalone mode STARTUP
Mar 8 13:19:18 freenas ntpd[2991]: time reset +0.618589 s
Mar 8 13:19:31 freenas smartd[3840]: Device: /dev/ada9, 3 Currently unreadable (pending) sectors
Mar 8 13:19:35 freenas smartd[3840]: Device: /dev/ada9, 3 Offline uncorrectable sectors
Mar 8 13:19:39 freenas smartd[3840]: Device: /dev/ada8, 73 Currently unreadable (pending) sectors
Mar 8 13:19:42 freenas smartd[3840]: Device: /dev/ada8, 73 Offline uncorrectable sectors
Mar 8 13:19:51 freenas avahi-daemon[4024]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Mar 8 13:19:51 freenas afpd[4035]: AFP/TCP started, advertising 192.168.2.5:548 (2.2.3)
Mar 8 13:24:19 freenas kernel: siisch4: Timeout on slot 30
Mar 8 13:24:19 freenas kernel: siisch4: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801d2000 serr 00000000
Mar 8 13:24:19 freenas kernel: siisch4: ... waiting for slots 20000000
Mar 8 13:24:19 freenas kernel: siisch4: Timeout on slot 29
Mar 8 13:30:02 freenas kernel: siisch4: Timeout on slot 30
Mar 8 13:30:02 freenas kernel: siisch4: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801d2000 serr 00000000
Mar 8 13:30:02 freenas kernel: siisch4: ... waiting for slots 20000000
Mar 8 13:30:02 freenas kernel: siisch4: Timeout on slot 29
Mar 8 13:30:37 freenas kernel: siisch4: Timeout on slot 30
Mar 8 13:30:37 freenas kernel: siisch4: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801d2000 serr 00000000
Mar 8 13:30:37 freenas kernel: siisch4: ... waiting for slots 20000000
Mar 8 13:30:37 freenas kernel: siisch4: Timeout on slot 29
Mar 8 13:35:11 freenas ntpd[2991]: kernel time sync status change 2001
Mar 8 13:50:26 freenas kernel: siisch4: Timeout on slot 30
Mar 8 13:50:26 freenas kernel: siisch4: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801d2000 serr 00000000
Mar 8 13:50:26 freenas kernel: siisch4: ... waiting for slots 20000000
Mar 8 13:50:26 freenas kernel: siisch4: Timeout on slot 29
Mar 8 13:50:50 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:50:50 freenas kernel: siisch2: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801c2000 serr 00000000
Mar 8 13:50:50 freenas kernel: siisch2: ... waiting for slots 3c000000
Mar 8 13:50:50 freenas kernel: siisch2: Timeout on slot 29
Mar 8 13:50:50 freenas kernel: siisch2: ... waiting for slots 1c000000
Mar 8 13:50:50 freenas kernel: siisch2: Timeout on slot 28
Mar 8 13:50:50 freenas kernel: siisch2: ... waiting for slots 0c000000
Mar 8 13:50:50 freenas kernel: siisch2: Timeout on slot 27
Mar 8 13:50:50 freenas kernel: siisch2: ... waiting for slots 04000000
Mar 8 13:50:50 freenas kernel: siisch2: Timeout on slot 26
Mar 8 13:50:58 freenas kernel: siisch4: Timeout on slot 29
Mar 8 13:50:58 freenas kernel: siisch4: siis_timeout is 00040000 ss 20000000 rs 20000000 es 00000000 sts 801f2000 serr 00000000
Mar 8 13:50:58 freenas kernel: (ada11:siisch4:0:1:0): lost device
Mar 8 13:51:30 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:51:30 freenas kernel: siisch2: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801c2000 serr 00000000
Mar 8 13:51:30 freenas kernel: siisch2: ... waiting for slots 3c000000
Mar 8 13:51:30 freenas kernel: siisch2: Timeout on slot 29
Mar 8 13:51:30 freenas kernel: siisch2: ... waiting for slots 1c000000
Mar 8 13:51:30 freenas kernel: siisch2: Timeout on slot 28
Mar 8 13:51:30 freenas kernel: siisch2: ... waiting for slots 0c000000
Mar 8 13:51:30 freenas kernel: siisch2: Timeout on slot 27
Mar 8 13:51:30 freenas kernel: siisch2: ... waiting for slots 04000000
Mar 8 13:51:30 freenas kernel: siisch2: Timeout on slot 26
Mar 8 13:51:45 freenas kernel: siisch4: Timeout on slot 30
Mar 8 13:51:45 freenas kernel: siisch4: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801d2000 serr 00000000
Mar 8 13:51:45 freenas kernel: siisch4: ... waiting for slots 20000000
Mar 8 13:51:45 freenas kernel: siisch4: Timeout on slot 29
Mar 8 13:52:00 freenas kernel: (ada10:siisch4:0:0:0): lost device
Mar 8 13:52:00 freenas kernel: (pmp2:siisch4:0:15:0): lost device
Mar 8 13:52:10 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:52:10 freenas kernel: siisch2: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801c2000 serr 00000000
Mar 8 13:52:10 freenas kernel: siisch2: ... waiting for slots 3c000000
Mar 8 13:52:10 freenas kernel: siisch2: Timeout on slot 29
Mar 8 13:52:10 freenas kernel: siisch2: ... waiting for slots 1c000000
Mar 8 13:52:10 freenas kernel: siisch2: Timeout on slot 28
Mar 8 13:52:10 freenas kernel: siisch2: ... waiting for slots 0c000000
Mar 8 13:52:10 freenas kernel: siisch2: Timeout on slot 27
Mar 8 13:52:10 freenas kernel: siisch2: ... waiting for slots 04000000
Mar 8 13:52:10 freenas kernel: siisch2: Timeout on slot 26
Mar 8 13:52:30 freenas kernel: siisch4: Timeout on slot 30
Mar 8 13:52:30 freenas kernel: siisch4: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:52:38 freenas kernel: siisch0: Timeout on slot 30
Mar 8 13:52:38 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:52:38 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 13:52:38 freenas kernel: siisch0: Timeout on slot 29
Mar 8 13:52:38 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 13:52:38 freenas kernel: siisch0: Timeout on slot 28
Mar 8 13:52:38 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 13:52:38 freenas kernel: siisch0: Timeout on slot 27
Mar 8 13:52:38 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 13:52:38 freenas kernel: siisch0: Timeout on slot 26
Mar 8 13:52:45 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:52:45 freenas kernel: siisch2: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801a2000 serr 00000000
Mar 8 13:52:45 freenas kernel: siisch2: ... waiting for slots 3c000000
Mar 8 13:52:45 freenas kernel: siisch2: Timeout on slot 29
Mar 8 13:52:45 freenas kernel: siisch2: ... waiting for slots 1c000000
Mar 8 13:52:45 freenas kernel: siisch2: Timeout on slot 28
Mar 8 13:52:45 freenas kernel: siisch2: ... waiting for slots 0c000000
Mar 8 13:52:45 freenas kernel: siisch2: Timeout on slot 27
Mar 8 13:52:45 freenas kernel: siisch2: ... waiting for slots 04000000
Mar 8 13:52:45 freenas kernel: siisch2: Timeout on slot 26
Mar 8 13:52:45 freenas kernel: (ada7:siisch2:0:2:0): lost device
Mar 8 13:52:56 freenas kernel: siisch4: Timeout on slot 30
Mar 8 13:52:56 freenas kernel: siisch4: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:52:57 freenas kernel: (pmp2:siisch4:0:15:0): removing device entry
Mar 8 13:53:11 freenas kernel: siisch0: Timeout on slot 30
Mar 8 13:53:11 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:53:11 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 13:53:11 freenas kernel: siisch0: Timeout on slot 29
Mar 8 13:53:11 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 13:53:11 freenas kernel: siisch0: Timeout on slot 28
Mar 8 13:53:11 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 13:53:11 freenas kernel: siisch0: Timeout on slot 27
Mar 8 13:53:11 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 13:53:11 freenas kernel: siisch0: Timeout on slot 26
Mar 8 13:53:32 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:53:32 freenas kernel: siisch2: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:53:32 freenas kernel: siisch2: ... waiting for slots 20000000
Mar 8 13:53:32 freenas kernel: siisch2: Timeout on slot 29
Mar 8 13:53:32 freenas kernel: (ada8:siisch2:0:3:0): lost device
Mar 8 13:53:43 freenas kernel: siisch0: Timeout on slot 30
Mar 8 13:53:43 freenas kernel: siisch0: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801f2000 serr 00000000
Mar 8 13:53:43 freenas kernel: siisch0: ... waiting for slots 20000000
Mar 8 13:53:43 freenas kernel: siisch0: Timeout on slot 29
Mar 8 13:53:43 freenas kernel: (ada1:siisch0:0:1:0): lost device
Mar 8 13:53:43 freenas kernel: (ada0:siisch0:0:0:0): lost device
Mar 8 13:54:04 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:54:04 freenas kernel: siisch2: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801f2000 serr 00000000
Mar 8 13:54:04 freenas kernel: (ada5:siisch2:0:0:0): lost device
Mar 8 13:54:36 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:54:36 freenas kernel: siisch2: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801f2000 serr 00000000
Mar 8 13:54:36 freenas kernel: (ada6:siisch2:0:1:0): lost device
Mar 8 13:54:45 freenas kernel: siisch0: Timeout on slot 30
Mar 8 13:54:45 freenas kernel: siisch0: siis_timeout is 00040000 ss 70000000 rs 70000000 es 00000000 sts 801c2000 serr 00000000
Mar 8 13:54:45 freenas kernel: siisch0: ... waiting for slots 30000000
Mar 8 13:54:45 freenas kernel: siisch0: Timeout on slot 29
Mar 8 13:54:45 freenas kernel: siisch0: ... waiting for slots 10000000
Mar 8 13:54:45 freenas kernel: siisch0: Timeout on slot 28
Mar 8 13:55:00 freenas kernel: (ada2:siisch0:0:2:0): lost device
Mar 8 13:55:00 freenas kernel: (ada3:siisch0:0:3:0): lost device
Mar 8 13:55:00 freenas kernel: (ada4:siisch0:0:4:0): lost device
Mar 8 13:55:00 freenas kernel: (pmp0:siisch0:0:15:0): lost device
Mar 8 13:55:53 freenas kernel: siisch2: Timeout on slot 30
Mar 8 13:55:53 freenas kernel: siisch2: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:55:53 freenas kernel: (ada9:siisch2:0:4:0): lost device
Mar 8 13:56:00 freenas kernel: siisch0: Timeout on slot 30
Mar 8 13:56:00 freenas kernel: siisch0: siis_timeout is 00040000 ss 78000000 rs 78000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:56:00 freenas kernel: siisch0: ... waiting for slots 38000000
Mar 8 13:56:00 freenas kernel: siisch0: Timeout on slot 29
Mar 8 13:56:00 freenas kernel: siisch0: ... waiting for slots 18000000
Mar 8 13:56:00 freenas kernel: siisch0: Timeout on slot 28
Mar 8 13:56:00 freenas kernel: siisch0: ... waiting for slots 08000000
Mar 8 13:56:00 freenas kernel: siisch0: Timeout on slot 27
Mar 8 13:56:00 freenas kernel: (pmp0:siisch0:0:15:0): removing device entry
Mar 8 13:57:56 freenas kernel: pmp0 at siisch0 bus 0 scbus2 target 15 lun 0
Mar 8 13:57:56 freenas kernel: pmp0: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 13:57:56 freenas kernel: pmp0: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 13:57:56 freenas kernel: pmp0: 5 fan-out ports
Mar 8 13:58:44 freenas kernel: siisch0: Timeout on slot 30
Mar 8 13:58:44 freenas kernel: siisch0: siis_timeout is 00040000 ss 70000000 rs 70000000 es 00000000 sts 801c2000 serr 00000000
Mar 8 13:58:44 freenas kernel: siisch0: ... waiting for slots 30000000
Mar 8 13:58:44 freenas kernel: siisch0: Timeout on slot 29
Mar 8 13:58:44 freenas kernel: siisch0: ... waiting for slots 10000000
Mar 8 13:58:44 freenas kernel: siisch0: Timeout on slot 28
Mar 8 13:59:31 freenas kernel: siisch0: Timeout on slot 30
Mar 8 13:59:31 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 13:59:31 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 13:59:31 freenas kernel: siisch0: Timeout on slot 29
Mar 8 13:59:31 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 13:59:31 freenas kernel: siisch0: Timeout on slot 28
Mar 8 13:59:31 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 13:59:31 freenas kernel: siisch0: Timeout on slot 27
Mar 8 13:59:31 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 13:59:31 freenas kernel: siisch0: Timeout on slot 26
Mar 8 14:00:26 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:00:26 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:00:26 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 14:00:26 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:00:26 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 14:00:26 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:00:26 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 14:00:26 freenas kernel: siisch0: Timeout on slot 27
Mar 8 14:00:26 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 14:00:26 freenas kernel: siisch0: Timeout on slot 26
Mar 8 14:00:58 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:00:58 freenas kernel: siisch0: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801f2000 serr 00000000
Mar 8 14:01:06 freenas kernel: cam_periph_alloc: attempt to re-allocate valid device ada0 rejected flags 0x18 refcount 1
Mar 8 14:01:06 freenas kernel: adaasync: Unable to attach to new device due to status 0x6
Mar 8 14:01:45 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:01:45 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:01:45 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 14:01:45 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:01:45 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 14:01:45 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:01:45 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 14:01:45 freenas kernel: siisch0: Timeout on slot 27
Mar 8 14:01:45 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 14:01:45 freenas kernel: siisch0: Timeout on slot 26
Mar 8 14:02:32 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:02:32 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:02:32 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 14:02:32 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:02:32 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 14:02:32 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:02:32 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 14:02:32 freenas kernel: siisch0: Timeout on slot 27
Mar 8 14:02:32 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 14:02:32 freenas kernel: siisch0: Timeout on slot 26
Mar 8 14:03:05 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:03:05 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:03:05 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 14:03:05 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:03:05 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 14:03:05 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:03:05 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 14:03:05 freenas kernel: siisch0: Timeout on slot 27
Mar 8 14:03:05 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 14:03:05 freenas kernel: siisch0: Timeout on slot 26
Mar 8 14:03:37 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:03:37 freenas kernel: siisch0: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801f2000 serr 00000000
Mar 8 14:03:38 freenas kernel: cam_periph_alloc: attempt to re-allocate valid device ada0 rejected flags 0x18 refcount 1
Mar 8 14:03:38 freenas kernel: adaasync: Unable to attach to new device due to status 0x6
Mar 8 14:04:12 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:04:12 freenas kernel: siisch0: siis_timeout is 00040000 ss 7c000000 rs 7c000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:04:12 freenas kernel: siisch0: ... waiting for slots 3c000000
Mar 8 14:04:12 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:04:12 freenas kernel: siisch0: ... waiting for slots 1c000000
Mar 8 14:04:12 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:04:12 freenas kernel: siisch0: ... waiting for slots 0c000000
Mar 8 14:04:12 freenas kernel: siisch0: Timeout on slot 27
Mar 8 14:04:12 freenas kernel: siisch0: ... waiting for slots 04000000
Mar 8 14:04:12 freenas kernel: siisch0: Timeout on slot 26
Mar 8 14:04:43 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:04:43 freenas kernel: siisch0: siis_timeout is 00040000 ss 60000000 rs 60000000 es 00000000 sts 801f2000 serr 00000000
Mar 8 14:04:43 freenas kernel: siisch0: ... waiting for slots 20000000
Mar 8 14:04:43 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:05:45 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:05:45 freenas kernel: siisch0: siis_timeout is 00040000 ss 70000000 rs 70000000 es 00000000 sts 801c2000 serr 00000000
Mar 8 14:05:45 freenas kernel: siisch0: ... waiting for slots 30000000
Mar 8 14:05:45 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:05:45 freenas kernel: siisch0: ... waiting for slots 10000000
Mar 8 14:05:45 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:06:00 freenas kernel: (pmp0:siisch0:0:15:0): lost device
Mar 8 14:07:01 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:07:01 freenas kernel: siisch0: siis_timeout is 00040000 ss 78000000 rs 78000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:07:01 freenas kernel: siisch0: ... waiting for slots 38000000
Mar 8 14:07:01 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:07:01 freenas kernel: siisch0: ... waiting for slots 18000000
Mar 8 14:07:01 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:07:01 freenas kernel: siisch0: ... waiting for slots 08000000
Mar 8 14:07:01 freenas kernel: siisch0: Timeout on slot 27
Mar 8 14:07:01 freenas kernel: (pmp0:siisch0:0:15:0): removing device entry
Mar 8 14:07:32 freenas kernel: cam_periph_alloc: attempt to re-allocate valid device ada0 rejected flags 0x18 refcount 1
Mar 8 14:07:32 freenas kernel: adaasync: Unable to attach to new device due to status 0x6
Mar 8 14:09:30 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:09:30 freenas kernel: siisch0: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:10:40 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:10:40 freenas kernel: siisch0: siis_timeout is 00040000 ss 40000000 rs 40000000 es 00000000 sts 801e2000 serr 00000000
Mar 8 14:19:49 freenas kernel: pmp0 at siisch0 bus 0 scbus2 target 15 lun 0
Mar 8 14:19:49 freenas kernel: pmp0: <Port Multiplier 37261095 1706> ATA-0 device
Mar 8 14:19:49 freenas kernel: pmp0: 300.000MB/s transfers (SATA 2.x, NONE, PIO 8192bytes)
Mar 8 14:19:49 freenas kernel: pmp0: 5 fan-out ports
Mar 8 14:19:54 freenas kernel: cam_periph_alloc: attempt to re-allocate valid device ada3 rejected flags 0x18 refcount 1
Mar 8 14:19:54 freenas kernel: adaasync: Unable to attach to new device due to status 0x6
Mar 8 14:19:54 freenas kernel: cam_periph_alloc: attempt to re-allocate valid device ada2 rejected flags 0x18 refcount 1
Mar 8 14:19:54 freenas kernel: cam_periph_alloc: attempt to re-allocate valid device ada4 rejected flags 0x18 refcount 1
Mar 8 14:20:41 freenas kernel: siisch0: Timeout on slot 30
Mar 8 14:20:41 freenas kernel: siisch0: siis_timeout is 00040000 ss 70000000 rs 70000000 es 00000000 sts 801c2000 serr 00000000
Mar 8 14:20:41 freenas kernel: siisch0: ... waiting for slots 30000000
Mar 8 14:20:41 freenas kernel: siisch0: Timeout on slot 29
Mar 8 14:20:41 freenas kernel: siisch0: ... waiting for slots 10000000
Mar 8 14:20:41 freenas kernel: siisch0: Timeout on slot 28
Mar 8 14:20:43 freenas kernel: (pmp0:siisch0:0:15:0): lost device
Mar 8 14:20:43 freenas kernel: (pmp0:siisch0:0:15:0): removing device entry
Mar 8 16:10:12 freenas afpd[8288]: pam_winbind(netatalk): user '-----' granted access
Mar 8 16:10:12 freenas afpd[8288]: AFP3.3 Login by -----
Mar 8 17:42:43 freenas newsyslog[1976]: logfile first created
Mar 8 17:42:43 freenas syslogd: kernel boot file is /boot/kernel/kernel
Mar 8 17:42:43 freenas kernel: Copyright (c) 1992-2012 The FreeBSD Project.
Mar 8 17:42:43 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Mar 8 17:42:43 freenas kernel: The Regents of the University of California. All rights reserved.
Mar 8 17:42:43 freenas kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Mar 8 17:42:43 freenas kernel: FreeBSD 8.3-RELEASE-p5 #2 r244158M: Wed Dec 12 10:04:42 PST 2012
Mar 8 17:42:43 freenas kernel: root@build.ixsystems.com:/home/jpaetzel/8.3.0/os-base/amd64/usr/home/jpaetzel/8.3.0/FreeBSD/src/sys/FREENAS.amd64 amd64
Mar 8 17:42:43 freenas kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Mar 8 17:42:43 freenas kernel: CPU: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz (2831.63-MHz K8-class CPU)
Mar 8 17:42:43 freenas kernel: Origin = "GenuineIntel" Id = 0x106a5 Family = 6 Model = 1a Stepping = 5
Mar 8 17:42:43 freenas kernel: Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Mar 8 17:42:43 freenas kernel: Features2=0x98e3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,POPCNT>
Mar 8 17:42:43 freenas kernel: AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
Mar 8 17:42:43 freenas kernel: AMD Features2=0x1<LAHF>
Mar 8 17:42:43 freenas kernel: TSC: P-state invariant
Mar 8 17:42:43 freenas kernel: real memory = 12884901888 (12288 MB)
Mar 8 17:42:43 freenas kernel: avail memory = 12370894848 (11797 MB)
Mar 8 17:42:43 freenas kernel: ACPI APIC Table: <022410 APIC1223>
Mar 8 17:42:43 freenas kernel: FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
Mar 8 17:42:43 freenas kernel: FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads
Mar 8 17:42:43 freenas kernel: cpu0 (BSP): APIC ID: 0
Mar 8 17:42:43 freenas kernel: cpu1 (AP): APIC ID: 1
Mar 8 17:42:43 freenas kernel: cpu2 (AP): APIC ID: 2
Mar 8 17:42:43 freenas kernel: cpu3 (AP): APIC ID: 3
Mar 8 17:42:43 freenas kernel: cpu4 (AP): APIC ID: 4
Mar 8 17:42:43 freenas kernel: cpu5 (AP): APIC ID: 5
Mar 8 17:42:43 freenas kernel: cpu6 (AP): APIC ID: 6
Mar 8 17:42:43 freenas kernel: cpu7 (AP): APIC ID: 7
Mar 8 17:42:43 freenas kernel: WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Mar 8 17:42:43 freenas kernel: ioapic0 <Version 2.0> irqs 0-23 on motherboard
Mar 8 17:42:43 freenas kernel: ioapic1 <Version 2.0> irqs 24-47 on motherboard
Mar 8 17:42:43 freenas kernel: kbd1 at kbdmux0
Mar 8 17:42:43 freenas kernel: hpt27xx: RocketRAID 27xx controller driver v1.0 (Dec 12 2012 10:04:31)
Mar 8 17:42:43 freenas kernel: cryptosoft0: <software crypto> on motherboard
Mar 8 17:42:43 freenas kernel: aesni0: No AESNI support.
Mar 8 17:42:43 freenas kernel: acpi0: <022410 RSDT1223> on motherboard
Mar 8 17:42:43 freenas kernel: acpi0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: acpi0: Power Button (fixed)
Mar 8 17:42:43 freenas kernel: acpi0: reservation of fee00000, 1000 (3) failed
Mar 8 17:42:43 freenas kernel: acpi0: reservation of 0, a0000 (3) failed
Mar 8 17:42:43 freenas kernel: acpi0: reservation of 100000, bff00000 (3) failed
Mar 8 17:42:43 freenas kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
Mar 8 17:42:43 freenas kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
Mar 8 17:42:43 freenas kernel: cpu0: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: cpu1: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: cpu2: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: cpu3: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: cpu4: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: cpu5: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: cpu6: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: cpu7: <ACPI CPU> on acpi0
Mar 8 17:42:43 freenas kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Mar 8 17:42:43 freenas kernel: pci0: <ACPI PCI bus> on pcib0
Mar 8 17:42:43 freenas kernel: pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
Mar 8 17:42:43 freenas kernel: pci1: <ACPI PCI bus> on pcib1
Mar 8 17:42:43 freenas kernel: atapci0: <Marvell ATA controller> port 0x8c00-0x8c07,0x8880-0x8883,0x8800-0x8807,0x8480-0x8483,0x8400-0x840f mem 0xf8dff800-0xf8dfffff irq 28 at device 0.0 on pci1
Mar 8 17:42:43 freenas kernel: atapci0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: ata2: <ATA channel> at channel 0 on atapci0
Mar 8 17:42:43 freenas kernel: ata2: [ITHREAD]
Mar 8 17:42:43 freenas kernel: ata3: <ATA channel> at channel 1 on atapci0
Mar 8 17:42:43 freenas kernel: ata3: [ITHREAD]
Mar 8 17:42:43 freenas kernel: pcib2: <ACPI PCI-PCI bridge> at device 2.0 on pci0
Mar 8 17:42:43 freenas kernel: pci2: <ACPI PCI bus> on pcib2
Mar 8 17:42:43 freenas kernel: pci2: <serial bus, USB> at device 0.0 (no driver attached)
Mar 8 17:42:43 freenas kernel: pcib3: <ACPI PCI-PCI bridge> at device 3.0 on pci0
Mar 8 17:42:43 freenas kernel: pci3: <ACPI PCI bus> on pcib3
Mar 8 17:42:43 freenas kernel: pcib4: <PCI-PCI bridge> irq 24 at device 0.0 on pci3
Mar 8 17:42:43 freenas kernel: pci4: <PCI bus> on pcib4
Mar 8 17:42:43 freenas kernel: siis0: <SiI3124 SATA controller> port 0x9c00-0x9c0f mem 0xf8fffc00-0xf8fffc7f,0xf8ff0000-0xf8ff7fff irq 24 at device 4.0 on pci4
Mar 8 17:42:43 freenas kernel: siis0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch0: <SIIS channel> at channel 0 on siis0
Mar 8 17:42:43 freenas kernel: siisch0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch1: <SIIS channel> at channel 1 on siis0
Mar 8 17:42:43 freenas kernel: siisch1: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch2: <SIIS channel> at channel 2 on siis0
Mar 8 17:42:43 freenas kernel: siisch2: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch3: <SIIS channel> at channel 3 on siis0
Mar 8 17:42:43 freenas kernel: siisch3: [ITHREAD]
Mar 8 17:42:43 freenas kernel: pcib5: <ACPI PCI-PCI bridge> at device 7.0 on pci0
Mar 8 17:42:43 freenas kernel: pci5: <ACPI PCI bus> on pcib5
Mar 8 17:42:43 freenas kernel: vgapci0: <VGA-compatible display> mem 0xfa000000-0xfaffffff,0xd0000000-0xdfffffff,0xf9000000-0xf9ffffff irq 30 at device 0.0 on pci5
Mar 8 17:42:43 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.0 (no driver attached)
Mar 8 17:42:43 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.1 (no driver attached)
Mar 8 17:42:43 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.2 (no driver attached)
Mar 8 17:42:43 freenas kernel: pci0: <base peripheral, interrupt controller> at device 20.3 (no driver attached)
Mar 8 17:42:43 freenas kernel: uhci0: <Intel 82801JI (ICH10) USB controller USB-D> port 0x7800-0x781f irq 16 at device 26.0 on pci0
Mar 8 17:42:43 freenas kernel: uhci0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus0: <Intel 82801JI (ICH10) USB controller USB-D> on uhci0
Mar 8 17:42:43 freenas kernel: uhci1: <Intel 82801JI (ICH10) USB controller USB-E> port 0x7880-0x789f irq 21 at device 26.1 on pci0
Mar 8 17:42:43 freenas kernel: uhci1: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus1: <Intel 82801JI (ICH10) USB controller USB-E> on uhci1
Mar 8 17:42:43 freenas kernel: uhci2: <Intel 82801JI (ICH10) USB controller USB-F> port 0x7c00-0x7c1f irq 19 at device 26.2 on pci0
Mar 8 17:42:43 freenas kernel: uhci2: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus2: <Intel 82801JI (ICH10) USB controller USB-F> on uhci2
Mar 8 17:42:43 freenas kernel: ehci0: <Intel 82801JI (ICH10) USB 2.0 controller USB-B> mem 0xf8cff000-0xf8cff3ff irq 18 at device 26.7 on pci0
Mar 8 17:42:43 freenas kernel: ehci0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus3: EHCI version 1.0
Mar 8 17:42:43 freenas kernel: usbus3: <Intel 82801JI (ICH10) USB 2.0 controller USB-B> on ehci0
Mar 8 17:42:43 freenas kernel: pci0: <multimedia, HDA> at device 27.0 (no driver attached)
Mar 8 17:42:43 freenas kernel: pcib6: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
Mar 8 17:42:43 freenas kernel: pci11: <ACPI PCI bus> on pcib6
Mar 8 17:42:43 freenas kernel: pcib7: <ACPI PCI-PCI bridge> irq 16 at device 28.1 on pci0
Mar 8 17:42:43 freenas kernel: pci9: <ACPI PCI bus> on pcib7
Mar 8 17:42:43 freenas kernel: pcib8: <PCI-PCI bridge> irq 17 at device 0.0 on pci9
Mar 8 17:42:43 freenas kernel: pci10: <PCI bus> on pcib8
Mar 8 17:42:43 freenas kernel: siis1: <SiI3124 SATA controller> port 0xdc00-0xdc0f mem 0xfbdffc00-0xfbdffc7f,0xfbdf0000-0xfbdf7fff irq 17 at device 4.0 on pci10
Mar 8 17:42:43 freenas kernel: siis1: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch4: <SIIS channel> at channel 0 on siis1
Mar 8 17:42:43 freenas kernel: siisch4: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch5: <SIIS channel> at channel 1 on siis1
Mar 8 17:42:43 freenas kernel: siisch5: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch6: <SIIS channel> at channel 2 on siis1
Mar 8 17:42:43 freenas kernel: siisch6: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch7: <SIIS channel> at channel 3 on siis1
Mar 8 17:42:43 freenas kernel: siisch7: [ITHREAD]
Mar 8 17:42:43 freenas kernel: pcib9: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
Mar 8 17:42:43 freenas kernel: pci8: <ACPI PCI bus> on pcib9
Mar 8 17:42:43 freenas kernel: mskc0: <Marvell Yukon 88E8056 Gigabit Ethernet> port 0xc800-0xc8ff mem 0xfbcfc000-0xfbcfffff irq 18 at device 0.0 on pci8
Mar 8 17:42:43 freenas kernel: msk0: <Marvell Technology Group Ltd. Yukon EC Ultra Id 0xb4 Rev 0x03> on mskc0
Mar 8 17:42:43 freenas kernel: msk0: Ethernet address: 48:5b:39:45:08:8a
Mar 8 17:42:43 freenas kernel: miibus0: <MII bus> on msk0
Mar 8 17:42:43 freenas kernel: e1000phy0: <Marvell 88E1149 Gigabit PHY> PHY 0 on miibus0
Mar 8 17:42:43 freenas kernel: e1000phy0: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Mar 8 17:42:43 freenas kernel: mskc0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: pcib10: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
Mar 8 17:42:43 freenas kernel: pci7: <ACPI PCI bus> on pcib10
Mar 8 17:42:43 freenas kernel: siis2: <SiI3132 SATA controller> port 0xbc00-0xbc7f mem 0xfbbffc00-0xfbbffc7f,0xfbbf8000-0xfbbfbfff irq 16 at device 0.0 on pci7
Mar 8 17:42:43 freenas kernel: siis2: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch8: <SIIS channel> at channel 0 on siis2
Mar 8 17:42:43 freenas kernel: siisch8: [ITHREAD]
Mar 8 17:42:43 freenas kernel: siisch9: <SIIS channel> at channel 1 on siis2
Mar 8 17:42:43 freenas kernel: siisch9: [ITHREAD]
Mar 8 17:42:43 freenas kernel: pcib11: <ACPI PCI-PCI bridge> irq 16 at device 28.5 on pci0
Mar 8 17:42:43 freenas kernel: pci6: <ACPI PCI bus> on pcib11
Mar 8 17:42:43 freenas kernel: mskc1: <Marvell Yukon 88E8056 Gigabit Ethernet> port 0xa800-0xa8ff mem 0xfbafc000-0xfbafffff irq 17 at device 0.0 on pci6
Mar 8 17:42:43 freenas kernel: msk1: <Marvell Technology Group Ltd. Yukon EC Ultra Id 0xb4 Rev 0x03> on mskc1
Mar 8 17:42:43 freenas kernel: msk1: Ethernet address: 48:5b:39:45:01:00
Mar 8 17:42:43 freenas kernel: miibus1: <MII bus> on msk1
Mar 8 17:42:43 freenas kernel: e1000phy1: <Marvell 88E1149 Gigabit PHY> PHY 0 on miibus1
Mar 8 17:42:43 freenas kernel: e1000phy1: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Mar 8 17:42:43 freenas kernel: mskc1: [ITHREAD]
Mar 8 17:42:43 freenas kernel: uhci3: <Intel 82801JI (ICH10) USB controller USB-A> port 0x7080-0x709f irq 23 at device 29.0 on pci0
Mar 8 17:42:43 freenas kernel: uhci3: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus4: <Intel 82801JI (ICH10) USB controller USB-A> on uhci3
Mar 8 17:42:43 freenas kernel: uhci4: <Intel 82801JI (ICH10) USB controller USB-B> port 0x7400-0x741f irq 19 at device 29.1 on pci0
Mar 8 17:42:43 freenas kernel: uhci4: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus5: <Intel 82801JI (ICH10) USB controller USB-B> on uhci4
Mar 8 17:42:43 freenas kernel: uhci5: <Intel 82801JI (ICH10) USB controller USB-C> port 0x7480-0x749f irq 18 at device 29.2 on pci0
Mar 8 17:42:43 freenas kernel: uhci5: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus6: <Intel 82801JI (ICH10) USB controller USB-C> on uhci5
Mar 8 17:42:43 freenas kernel: ehci1: <Intel 82801JI (ICH10) USB 2.0 controller USB-A> mem 0xf8cfe000-0xf8cfe3ff irq 23 at device 29.7 on pci0
Mar 8 17:42:43 freenas kernel: ehci1: [ITHREAD]
Mar 8 17:42:43 freenas kernel: usbus7: EHCI version 1.0
Mar 8 17:42:43 freenas kernel: usbus7: <Intel 82801JI (ICH10) USB 2.0 controller USB-A> on ehci1
Mar 8 17:42:43 freenas kernel: pcib12: <ACPI PCI-PCI bridge> at device 30.0 on pci0
Mar 8 17:42:43 freenas kernel: pci12: <ACPI PCI bus> on pcib12
Mar 8 17:42:43 freenas kernel: fwohci0: <VIA Fire II (VT6306)> port 0xec00-0xec7f mem 0xfbeff000-0xfbeff7ff irq 18 at device 2.0 on pci12
Mar 8 17:42:43 freenas kernel: fwohci0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: fwohci0: OHCI version 1.10 (ROM=1)
Mar 8 17:42:43 freenas kernel: fwohci0: No. of Isochronous channels is 4.
Mar 8 17:42:43 freenas kernel: fwohci0: EUI64 00:1e:8c:00:00:d5:50:f3
Mar 8 17:42:43 freenas kernel: fwohci0: Phy 1394a available S400, 2 ports.
Mar 8 17:42:43 freenas kernel: fwohci0: Link S400, max_rec 2048 bytes.
Mar 8 17:42:43 freenas kernel: firewire0: <IEEE1394(FireWire) bus> on fwohci0
Mar 8 17:42:43 freenas kernel: sbp0: <SBP-2/SCSI over FireWire> on firewire0
Mar 8 17:42:43 freenas kernel: fwohci0: Initiate bus reset
Mar 8 17:42:43 freenas kernel: fwohci0: fwohci_intr_core: BUS reset
Mar 8 17:42:43 freenas kernel: fwohci0: fwohci_intr_core: node_id=0x00000000, SelfID Count=1, CYCLEMASTER mode
Mar 8 17:42:43 freenas kernel: isab0: <PCI-ISA bridge> at device 31.0 on pci0
Mar 8 17:42:43 freenas kernel: isa0: <ISA bus> on isab0
Mar 8 17:42:43 freenas kernel: atapci1: <Intel ICH10 SATA300 controller> port 0x6000-0x6007,0x5c00-0x5c03,0x5880-0x5887,0x5800-0x5803,0x5480-0x548f,0x5400-0x540f irq 20 at device 31.2 on pci0
Mar 8 17:42:43 freenas kernel: atapci1: [ITHREAD]
Mar 8 17:42:43 freenas kernel: ata4: <ATA channel> at channel 0 on atapci1
Mar 8 17:42:43 freenas kernel: ata4: [ITHREAD]
Mar 8 17:42:43 freenas kernel: ata5: <ATA channel> at channel 1 on atapci1
Mar 8 17:42:43 freenas kernel: ata5: [ITHREAD]
Mar 8 17:42:43 freenas kernel: pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
Mar 8 17:42:43 freenas kernel: atapci2: <Intel ICH10 SATA300 controller> port 0x7000-0x7007,0x6c00-0x6c03,0x6880-0x6887,0x6800-0x6803,0x6480-0x648f,0x6400-0x640f irq 20 at device 31.5 on pci0
Mar 8 17:42:43 freenas kernel: atapci2: [ITHREAD]
Mar 8 17:42:43 freenas kernel: ata6: <ATA channel> at channel 0 on atapci2
Mar 8 17:42:43 freenas kernel: ata6: [ITHREAD]
Mar 8 17:42:43 freenas kernel: ata7: <ATA channel> at channel 1 on atapci2
Mar 8 17:42:43 freenas kernel: ata7: [ITHREAD]
Mar 8 17:42:43 freenas kernel: acpi_button0: <Power Button> on acpi0
Mar 8 17:42:43 freenas kernel: atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Mar 8 17:42:43 freenas kernel: acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Mar 8 17:42:43 freenas kernel: Timecounter "HPET" frequency 14318180 Hz quality 900
Mar 8 17:42:43 freenas kernel: qpi0: <QPI system bus> on motherboard
Mar 8 17:42:43 freenas kernel: pcib13: <QPI Host-PCI bridge> pcibus 255 on qpi0
Mar 8 17:42:43 freenas kernel: pci255: <PCI bus> on pcib13
Mar 8 17:42:43 freenas kernel: sc0: <System console> at flags 0x100 on isa0
Mar 8 17:42:43 freenas kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Mar 8 17:42:43 freenas kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Mar 8 17:42:43 freenas kernel: atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
Mar 8 17:42:43 freenas kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Mar 8 17:42:43 freenas kernel: kbd0 at atkbd0
Mar 8 17:42:43 freenas kernel: atkbd0: [GIANT-LOCKED]
Mar 8 17:42:43 freenas kernel: atkbd0: [ITHREAD]
Mar 8 17:42:43 freenas kernel: ppc0: cannot reserve I/O port range
Mar 8 17:42:43 freenas kernel: coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Mar 8 17:42:43 freenas kernel: est0: <Enhanced SpeedStep Frequency Control> on cpu0
Mar 8 17:42:43 freenas kernel: p4tcc0: <CPU Frequency Thermal Control> on cpu0
Mar 8 17:42:43 freenas kernel: coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Mar 8 17:42:43 freenas kernel: est1: <Enhanced SpeedStep Frequency Control> on cpu1
Mar 8 17:42:43 freenas kernel: p4tcc1: <CPU Frequency Thermal Control> on cpu1
Mar 8 17:42:43 freenas kernel: coretemp2: <CPU On-Die Thermal Sensors> on cpu2
Mar 8 17:42:43 freenas kernel: est2: <Enhanced SpeedStep Frequency Control> on cpu2
Mar 8 17:42:43 freenas kernel: p4tcc2: <CPU Frequency Thermal Control> on cpu2
Mar 8 17:42:43 freenas kernel: coretemp3: <CPU On-Die Thermal Sensors> on cpu3
Mar 8 17:42:43 freenas kernel: est3: <Enhanced SpeedStep Frequency Control> on cpu3
Mar 8 17:42:43 freenas kernel: p4tcc3: <CPU Frequency Thermal Control> on cpu3
Mar 8 17:42:43 freenas kernel: coretemp4: <CPU On-Die Thermal Sensors> on cpu4
Mar 8 17:42:43 freenas kernel: est4: <Enhanced SpeedStep Frequency Control> on cpu4
Mar 8 17:42:43 freenas kernel: p4tcc4: <CPU Frequency Thermal Control> on cpu4
Mar 8 17:42:43 freenas kernel: coretemp5: <CPU On-Die Thermal Sensors> on cpu5
Mar 8 17:42:43 freenas kernel: est5: <Enhanced SpeedStep Frequency Control> on cpu5
Mar 8 17:42:43 freenas kernel: p4tcc5: <CPU Frequency Thermal Control> on cpu5
Mar 8 17:42:43 freenas kernel: coretemp6: <CPU On-Die Thermal Sensors> on cpu6
Mar 8 17:42:43 freenas kernel: est6: <Enhanced SpeedStep Frequency Control> on cpu6
Mar 8 17:42:43 freenas kernel: p4tcc6: <CPU Frequency Thermal Control> on cpu6
Mar 8 17:42:43 freenas kernel: coretemp7: <CPU On-Die Thermal Sensors> on cpu7
Mar 8 17:42:43 freenas kernel: est7: <Enhanced SpeedStep Frequency Control> on cpu7
Mar 8 17:42:43 freenas kernel: p4tcc7: <CPU Frequency Thermal Control> on cpu7
Mar 8 17:42:43 freenas kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Mar 8 17:42:43 freenas kernel: Timecounters tick every 1.000 msec
Mar 8 17:42:43 freenas kernel: hpt27xx: no controller detected.
Mar 8 17:42:43 freenas kernel: firewire0: 1 nodes, maxhop <= 0 cable IRM irm(0) (me)
Mar 8 17:42:43 freenas kernel: firewire0: bus manager 0
Mar 8 17:42:43 freenas kernel: (noperiph:siisch0:0:-1:-1): rescan already queued
Mar 8 17:42:43 freenas kernel: (noperiph:siisch2:0:-1:-1): rescan already queued
Mar 8 17:42:43 freenas kernel: (noperiph:siisch5:0:-1:-1): rescan already queued
Mar 8 17:42:43 freenas kernel: (noperiph:siisch6:0:-1:-1): rescan already queued
Mar 8 17:42:43 freenas kernel: (noperiph:siisch7:0:-1:-1): rescan already queued
Mar 8 17:42:43 freenas kernel: (noperiph:siisch8:0:-1:-1): rescan already queued
Mar 8 17:42:43 freenas kernel: (noperiph:siisch9:0:-1:-1): rescan already queued
Mar 8 17:42:43 freenas kernel: usbus0: 12Mbps Full Speed USB v1.0
Mar 8 17:42:43 freenas kernel: usbus1: 12Mbps Full Speed USB v1.0
Mar 8 17:42:43 freenas kernel: usbus2: 12Mbps Full Speed USB v1.0
Mar 8 17:42:43 freenas kernel: usbus3: 480Mbps High Speed USB v2.0
Mar 8 17:42:43 freenas kernel: usbus4: 12Mbps Full Speed USB v1.0
Mar 8 17:42:43 freenas kernel: usbus5: 12Mbps Full Speed USB v1.0
Mar 8 17:42:43 freenas kernel: usbus6: 12Mbps Full Speed USB v1.0
Mar 8 17:42:43 freenas kernel: usbus7: 480Mbps High Speed USB v2.0
Mar 8 17:42:43 freenas kernel: ugen0.1: <Intel> at usbus0
Mar 8 17:42:43 freenas kernel: uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
Mar 8 17:42:43 freenas kernel: ugen1.1: <Intel> at usbus1
Mar 8 17:42:43 freenas kernel: uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
Mar 8 17:42:43 freenas kernel: ugen2.1: <Intel> at usbus2
Mar 8 17:42:43 freenas kernel: uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
Mar 8 17:42:43 freenas kernel: ugen3.1: <Intel> at usbus3
Mar 8 17:42:43 freenas kernel: uhub3: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
Mar 8 17:42:43 freenas kernel: ugen4.1: <Intel> at usbus4
Mar 8 17:42:43 freenas kernel: uhub4: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
Mar 8 17:42:43 freenas kernel: ugen5.1: <Intel> at usbus5
Mar 8 17:42:43 freenas kernel: uhub5: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
Mar 8 17:42:43 freenas kernel: ugen6.1: <Intel> at usbus6
Mar 8 17:42:43 freenas kernel: uhub6: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
Mar 8 17:42:43 freenas kernel: ugen7.1: <Intel> at usbus7
Mar 8 17:42:43 freenas kernel: uhub7: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus7
Mar 8 17:42:43 freenas kernel: uhub0: 2 ports with 2 removable, self powered
Mar 8 17:42:43 freenas kernel: uhub1: 2 ports with 2 removable, self powered
Mar 8 17:42:43 freenas kernel: uhub2: 2 ports with 2 removable, self powered
Mar 8 17:42:43 freenas kernel: uhub4: 2 ports with 2 removable, self powered
Mar 8 17:42:43 freenas kernel: uhub5: 2 ports with 2 removable, self powered
Mar 8 17:42:43 freenas kernel: uhub6: 2 ports with 2 removable, self powered
...continued in next post...
