Evi Vanoost
 - Aug 4, 2016
You don't want to size your power supply based on idle power usage, you'll never get to the point of idle if it doesn't boot up.
But given your total peak power consumption is ~250W, a "good" 450W should suffice, the biggest consumers will be GPU and CPU, something like an nVidia Titan will kill that poor box though. Drives are ~10W, 1-5W for an SSD, swapping out one CPU for another is usually zero sum.
Very small boxes containing low end CPUs like the one the OP posted fit up to 2 or 4 drives with 250W power supplies.
