WayneC1972
- Oct 19, 2015
Just upgraded my FreeNAS server.
Went from:
To:
Do you think I should upgrade my power supply? If yes...to what?
Judging from this thread. I guess I should go to at least a 750?
Went from:
Case: Lian Li PC-Q25B
Motherboard: ASRock E3C226D2I Mini ITX Server Motherboard LGA 1150 Intel C226 DDR3 1600/1333
CPU:1 x Intel Xeon E3-1225v3 CPU 3.20GHz Quad Core SR1KX LGA1150 Processor
Memory:Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600 (PC3 12800) Server Memory Model CT2KIT102472BD160B
Hard Drive(s):6 x WD Red 3TB NAS Hard Drive: 1 to 8-bay RAID Hard Drive: 3.5-inch SATA 6 Gb/s, IntelliPower, 64MB Cache WD30EFRX
OS Drive:2xSanDisk Ultra Fit 32Gb USB 3.0 Flash Drives - Mirrored
SATA Controller Card:IO Crest 4 Port SATA III PCI-e 2.0 x1 Controller Card Marvell Non-Raid SI-PEX40064
Plex Drives: 1 x PNY 120GB (CS1311 SSD); 1 x Sandisk 120GB SSD plus -MIRRORED
Powersupply:Corsair RM Series 450-Watt ATX/EPS 80PLUS Gold-Certified Power Supply CP-9020066-NA
Additional NIC: Dell Intel Quad Port Gigabit Ethernet Card YT674 PCIe NIC Server
Battery Backup: CyberPower 1000PFCLCD
To:
OS: FreeNAS-11.0-RC3
Case: Lian Li PC-M25b
Motherboard: Supermicro MBD-X11SSH-LN4F
CPU: Intel® Xeon® Processor E3-1220 v5 (8M Cache, 3.00 GHz)
Memory: Kingston ValueRAM 32GB (2 x 16GB) DDR4 2133 RAM (Server Memory) ECC DIMM (288-Pin) KVR21E15D8K2/32I (Intel Validated)
Hard Drive(s):6 x WD Red 3TB NAS Hard Drive: 3.5-inch SATA 6 Gb/s, IntelliPower, 64MB Cache WD30EFRX - RaidZ2
OS Drive:2 x SanDisk Ultra Fit 32Gb USB 3.0 Flash Drives - Mirrored
Jails/Plex Drives: 1 x PNY 120GB (CS1311 SSD); 1 x Sandisk 120GB SSD plus -MIRRORED
Powersupply: Corsair RM Series 450-Watt ATX/EPS 80PLUS Gold-Certified Power Supply CP-9020066-NA
