Tried to log into my FreeNAS today and it would not respond... When I went in to check on it, It appeared powered off. I think it died peaceably as there is no signs of struggle or heat stroke.
I get nothing from it - no lights, beeps, no feedback when the power switch it pressed.
The power supply checks out based on the paperclip shorting test to verify internal fans work.
CMOS battery =3.05 volts no load
Removed drives, memory, and cpu - no change.
tested by shorting reset and power pins. - no change
If anyone has any suggestions, I would appreciate hearing them.
