I currently have a Synology NAS and have a shared iSCSI drive that is shared between 2 hosts. These hosts are not in a cluster. Currently it works perfectly and I can stick a VM on either host and have them on the iSCSI datastore. I can then move the VM's if the host they are on needs to be shut down.
I now have a FreeNAS 11.3RC1 setup and want to do the same thing there. I have done some searches and some posts says it is not possible for two hosts to share the same iSCSI datastore the same way Synology does and other posts suggest it will work but don't say how.
I saw one suggestion that said to simply point each host to the same LUN and it would work.
Can someone please confirm if FreeNAS can do share an iSCSI datastore with more than one eSXI host that are not in a cluster. If they can what steps do I need.
Thanks.
Thanks.
