Prufrock
- Jun 2, 2011
I'm having recurring problems setting up FreeNAS 8 because ZFS locks up my computer, preventing it from booting or even showing the BIOS screen.
In outline, I want to set up FreeNAS on a spare machine as a backup device for two or three computers The system I want to use dates from about 2007 and has an Elite (ECS) KV2 Lite motherboard (VIA K8T800 chip and VIA 8237 south bridge). It has (as far as I can tell) the manufacturer's latest version of the Phoenix Award BIOS. I have a 400 Gb IDE drive I want to use as my first disk and to set this up there are currently no other disks connected to the motherboard.
Installation to a USB drive went fine, I could then log in to the web interface and format the drive using ZFS and do some initial configuration. However, once I reboot the machine it stops at the motherboard start-up page - pressing <delete> no longer lets me enter the BIOS setup, nor does <f2> let me enter the screen to temporarily select a first boot drive. Once I disconnect the ZFS drive, FreeNAS will boot up again - but of course there's no drive. The only way I could retrieve the drive was to remove it from the computer and put it in a USB enclosure (removing the existing disk) where I was able to use a disk utility to check the whole disk (it passed) and then repartition it temporarily so I could try again to see if I'd just made an error. The result was the same.
I've searched for any help on this - alll I have found so far is advice to set the BIOS so that the IDE disk detection for each IDE Channel is no longer <Auto> but is instead set to <None>. Unfortunately this makes no difference. The boot priority is set to start with the USB drive.
Can anyone help?
Would using a drive on the SATA connector avoid this problem? (A SATA drive would be a cheap upgrade - I don't really want to buy a new motherboard, processor and memory when this system, though using older components such as a 939 pin CPU and DDR2 memory, still works fine in other ways.)
Should I use UFS instead or is this system just not suitable for FreeNAS?
Thanks
Can anyone help?
Thanks
