Sorry for my poor english but I have some questions about the FreeNAS V8 installation on my computer. I try to install FreeNAS V8 RELEASE version from my USB CD drive to my USB key. After the installation, i can't boot to my usb key (i have the Asus M4A78LT-M motherboard). It seems that the usb key isn't a boot device. This is my first problem.
I can only boot to my usb key when i use the F8 key option (choose the device to boot) (partial solution). After the screen "Welcome to FreeNAS", i choose the first option "Boot FreeNAS (default)". But i have this message :
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ROOT MOUNT ERROR :
If you have invalid mount options, reboot, and first try the following from the loader prompt :
set vfs.root.mountfrom.options=rw
and then remove invalid mount options from /etc/fstab.
Loader variables:
vfs.root.mountfrom=ufs:/dev/ufs/FreeNASs1a
vfs.root.mountfrom.options=ro
I define the new set variable on the console but i can't modified the fstab file. (no nano or vi command on this "distribution"). Have you got any suggestion to resove this problem because i 'm really a noob on bsd/unix/linux.
Thanks in advance.
Some informations with the command line :
more /etc/fstab
*** FILE /etc/fstab BEGIN ***
/dev/ufs/FreeNASs1a / ufs ro 1 1
/dev/ufs/FreeNASs3 /cfg ufs rw,noauto 2 2
/dev/ufs/FreeNASs4 /data ufs rw 2 2
*** FILE /etc/fstab END ***
lsdev
**** FILE BEGIN
disk0: BIOS drive c:
disk0s2 : FFS bad disklabel
disk0s3 : FFS bad disklabel
disk0s4 : FFS bad disklabel
disk1 : BIOS drive D:
disk1s1: ext2fs
disk1s5: Linux swap
disk2 : BIOS drive E:
disk2s1: ext2fs
disk3 : BIOS drive F:
disk3s1: ext2fs
disk4 : BIOS drive G:
disk4s1: ext2fs
disk5 : BIOS drive H:
disk5s1: ext2fs
pwe devices:
****** FILE END
ROOT MOUNT ERROR :
Loader variables:
Thanks in advance.
more /etc/fstab
lsdev
**** FILE BEGIN
disk1s1: ext2fs
disk1s5: Linux swap
disk2s1: ext2fs
disk3s1: ext2fs
disk4s1: ext2fs
disk5s1: ext2fs
pwe devices:
****** FILE END
