voodoojaron
- Mar 30, 2013
Hi Everyone -
New to FreeNAS and new to the forum as well. I am mostly a Mac guy, so it is the intricacies of the Windows hardware world that you guys can help me with.
System:
Gateway GP7-450
450 MHZ CPU
128 MB RAM
No hard disk
OEM video card
OEM CD-ROM
OEM Floppy Disk
Zip Disk 100 Drive
The project is to be a fully functional FreeNAS backup server to my RAID array which contains digitized versions of all of my burned DVD backups. No streaming, no music, nothing else right now.
The BIOS version right now has already been upgraded to Phoenix 4W4SB0X0.15A.0019.P14.
Had some problems with the machine starting up, but reset the CMOS and all is well for now. This project is how to turn an inherited old (1998 running Windows 98SE) into a fully functional and reliable NAS device using the FreeNAS software and the gifts, talents, and advice of all of you fine folks.
1st problem: The machine WILL boot from a floppy disk with the BIOS update and WILL boot from both the Windows 98SE install CD and Windows XP install CD via the optical drive. Under no circumstance will the machine boot a copy of FreeNAS (tried both version 7 and 8.3.1) via optical drive or via USB thumb drive. The intent is to have an embedded copy under the IDE/ATA bus be the FreeNAS drive, with a SATA card added later for the larger storage drives.
Also, please - this IS the noob section, so be gentle and fully explain everything, if not for me than for others following this thread. The goal is to spend NO money or very, very little money. Repurposing is our goal here to prevent good PC's from going into the garbage.
Help and let's have fun!
System:
Gateway GP7-450
450 MHZ CPU
128 MB RAM
No hard disk
OEM video card
OEM CD-ROM
OEM Floppy Disk
Zip Disk 100 Drive
