Set permissions for new dataset created from python script
I have a python script that creates a dataset and a nfs share.
It was really simple to implement based on basic Freenas python function but I also need to set default persmissions for this newly created dataset.
Is there a way to do this from python like from the web interface under Dataset > Change permissions? I mainly need to change the group ownership.
Thanks for your help,
Kevin
anodos
Sambassador
Kevin
You may want to look into using the rest API for this.
Thank you for your answer.
That's exaclty what I'm doing so far. I should have been clearer in my question.
But using the following function, I don't know how to pass additional information such as ownership.
    def __create_dataset(self, path, **kwargs):
        parent, name = os.path.split(path)
        data = {'name': name}
        if kwargs:
            data.update(kwargs)
        self.request('/storage/dataset/%s' % parent, method='POST', data=data)
Can I append this to data through kwargs?
Kind regards,
Kevin
