Set SMB permissions recursively not working
papaja
After first installation I played with shares, users and settings. I ended up creating dataset media and sharing it as SMB share. Now on that dataset I have some folders created as user 1000, group wheel, which I would like removed.
I tried adding my user to group wheel, no luck.
I tried modifying permissions on that dataset and enabling Set permission recursively, again no luck. It does not change owner of those folders.
I enabled login for root in ssh service and manually deleted one folder, but I really do not like that approach.
Is there option to reset permissions on all folders in dataset to default windows style owner/group?
anodos
Sambassador
The option you're looking for is "apply default permissions" under the share settings in the web ui.
