- May 28, 2011
I actually have to disagree for once and that is not typically me for when it comes with instructions. I fell the wdidle program was provided with adequate instructions on how to format the command line and this is typical for most programs that return some generic command line help info. And if it doesn't make sense to you then you should do a Google (or your favorite seach engine) search for, in this case, "wdidle3 example". The problem is the user experience level. (I'm starting to sound like Cyberjock) And this type of tool was not designed for a non-technical person. I can see that the OP is on a steep learning curve and we will help out but you need to seriously learn some basics and do a little research as well. I'm certain you will get there.
