Scrub and SMART schedule
nakos
Hi everybody,
I spent last day to find a way to schedule:
- Scrub every Sunday at 2pm
- SMART long test every Wednesday at 2pm
Unfortunately no one of these works
Could you please explain to a stupid guy how can i set all the triggers to make it happen?
Thanks in advance and sorry for the stupid question!
nAKos
joeschmuck
Old Man
What version of FreeNAS are you using?
In the left hand pane open up Storage - > ZFS Scrub and if you don't have any scrub schedule then add one, if you do have a scrub schedule then edit it. You will find many settings that you can change but keep it setup as default except the hour you should change and scroll down to the bottom and select only Sunday.
You do similar setup for SMART which is under System -> SMART Tests. You will have to create long tests if you haven't already.
nakos
The version is 9.2.
How can i see if the scrub and SMART start properly? because from the console i don't have any message
joeschmuck
Old Man
From the shell type
smartctl -a /dev/ada0
assuming your first drive is ada0. This will list quite a bit of data and in there you will see test results. Correlate the hour it was run to the current hours of power on time and you will know when it was completed. Repeat this for all your drives, ada1, ada2, etc...
gpsguy
Active Member
For scrub results, run "zpool status -v" from the shell. Here's an example of the output.
scrub repaired 0 in 0h31m with 0 errors on Sat Jan 19 10:28:28 2013
nakos
This is how i set scrub...but unfortunately doesn't start!
For SMART I have drives da0, da1, etc... instead of ada0, ada1, etc... i think is the same process...is now set to start at 19pm (so in 15min for my local time)...i will let you know
Thank you
Those settings are set so that a scrub will occur every sunday at 1400, but only if there has been at least 35 days since the last completed scrub.
nakos
SMART suppose to start at 19pm as shown in the picture below...is it running?
Here the result of smartctl -a /dev/da1
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Desktop HDD.15
Device Model: ST4000DM000-1F2168
Serial Number: W300EP7B
LU WWN Device Id: 5 000c50 069963f49
Firmware Version: CC52
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Jan 5 19:10:34 2014 GST
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
data collection: ( 602) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 506) minutes.
Conveyance self-test routine
SCT capabilities: (0x1085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 201317120
3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 57
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 4315736237
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2233
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 31
183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 097 097 000 Old_age Always - 3
190 Airflow_Temperature_Cel 0x0022 069 049 045 Old_age Always - 31 (Min/Max 29/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 31
193 Load_Cycle_Count 0x0032 075 075 000 Old_age Always - 51845
194 Temperature_Celsius 0x0022 031 051 000 Old_age Always - 31 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1783h+33m+46.168s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 20339076153
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 44246030665
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Self-test routine in progress 90% 2233 -
# 2 Extended offline Completed without error 00% 2128 -
# 3 Short offline Completed without error 00% 2085 -
# 4 Short offline Completed without error 00% 1917 -
# 5 Extended offline Completed without error 00% 1385 -
# 6 Extended offline Completed without error 00% 669 -
# 7 Short offline Completed without error 00% 237 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
It is indeed running! Don't shutdown or reboot the server. :)
