SMART suppose to start at 19pm as shown in the picture below...is it running?
Here the result of smartctl -a /dev/da1
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke,
www.smartmontools.org
Model Family: Seagate Desktop HDD.15
Device Model: ST4000DM000-1F2168
Serial Number: W300EP7B
LU WWN Device Id: 5 000c50 069963f49
Firmware Version: CC52
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Jan 5 19:10:34 2014 GST
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
data collection: ( 602) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 506) minutes.
Conveyance self-test routine
SCT capabilities: (0x1085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 201317120
3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 57
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 4315736237
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2233
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 31
183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 097 097 000 Old_age Always - 3
190 Airflow_Temperature_Cel 0x0022 069 049 045 Old_age Always - 31 (Min/Max 29/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 31
193 Load_Cycle_Count 0x0032 075 075 000 Old_age Always - 51845
194 Temperature_Celsius 0x0022 031 051 000 Old_age Always - 31 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1783h+33m+46.168s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 20339076153
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 44246030665
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Self-test routine in progress 90% 2233 -
# 2 Extended offline Completed without error 00% 2128 -
# 3 Short offline Completed without error 00% 2085 -
# 4 Short offline Completed without error 00% 1917 -
# 5 Extended offline Completed without error 00% 1385 -
# 6 Extended offline Completed without error 00% 669 -
# 7 Short offline Completed without error 00% 237 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
