I know this is a thread about installing nextcloud using danb35's script. But as I'm running into problems with the latest version of nextcloud, when trying to download multiple items at once from the web UI.
I wanted to check if others have the same issue (version 28.0.2)??
To test it: Log in as a regular user, or admin, select a few files of any type; text, pictures etc. and click the Download button. I get an error and no file is downloaded... The windows explorer dialog that opens shows file name "download.htm" and an error that sais "site wasn't available"...
To test previous versions, I made a fresh install with version 26 (by changing the version number in danb's script) which worked fine. When trying to download multiple files I now get a zipfile as expected... I removed the jail and changed to version 27 in the script. After logging in as admin it sais version 27 is available for update, which I selected and ran, from the web UI. This also works perfectly fine, (27.1.6).
BUT, after I go to Administrative settings and clicking update, it goes through the procedure and I am again at the latest version 28.0.2, without and errors reported in the update log.
Now, downloading of multiple files no longer works...
The response over at the nextcloud forum is "
Do not use a script e.g. danb35/freenas-iocage-nextcloud. Use a normal installation guide that you can understand all parts of installation."
Furthermore I got the following comments:
Read here for needed packages. You need the package php-zip with e.g. /usr/lib/php/20220829/zip.so (belongs to php version).
freenas-iocage-nextcloud/nextcloud-jail.sh at master · danb35/freenas-iocage-nextcloud · GitHub
Maybe another error.
As far as I can see, zip has been installed and is working. There must be some other configuration error of sorts??
