N20Visuals
- Jan 16, 2021
Hi all,
i'm finally gotten around to set up another container after migrating from CORE to SCALE.
This time, syncthing. After fiddling with permissions now everything is working well, but i do have one problem:
inside the container the command doesn't work, so i'm wondering after reading this thread:
that i might have to increase this limit within scale itself. is that possible and if yes, should i do it? or do i risk instability or even worse issues?
on another note, is it possible to run every container as a different user to be able to give more granular access to the file system? now i have to grant all apps access to my folder, kinda unsafe...?
thank you for you help :)
"Cloud" failed to setup inotify handler. Please increase inotify limits, see https://docs.syncthing.net/users/faq.html#inotify-limits
Reddit - Dive into anything
www.reddit.com
