The plot thickens.  I went ahead and blew up the scale install and just installed Truenas Core 12 to see if the drives would cooperate.  It installed nicely and I was able to create my 2x200gb SSD pool.  When I went to create a pool with 2x mirrored VDEVs witht he 4 4TB drives I ran into trouble.  No matter how I laid this out or which drives I used I get an error that prevents the creation of the pool:
  File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
    await self.future
  File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
  File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 670, in do_create
    formatted_disks = await self.middleware.call('pool.format_disks', job, disks)
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1248, in call
    return await self._call(
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1205, in _call
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks
    await asyncio_map(format_disk, disks.items(), limit=16)
  File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
    return await asyncio.gather(*futures)
  File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 13, in func
    return await real_func(arg)
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1216, in _call
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1120, in run_in_executor
  File "/usr/local/lib/python3.9/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/format.py", line 25, in format
    raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk da0: [EFAULT] Command gpart create -s gpt /dev/da0 failed (code 1):
gpart: Input/output error
