Server Dell R450, 64GB RAM, swap 16GB, boot 2x600GB, vm 2x600GB, Dell 745 HBA mode.
Fresh installation - Truenas Scale in UEFI mode. I've got one Windows 10 Vm. Vm is allocated 16GB memory. VirtIO disk and network drivers. Cpu host passthrough. When I'm doing a disk benchmark software test - CrystalDiskMark on the VM, the Scale memory drops to zero. The swap is at max. WebUI not responding. In logs “Device /dev/by-partuid/... is causing slow I/O on pool. After a few minutes, memory is low and the virtual machine stops. It looks like vm is taking up more than 16GB. Truenas had an unscheduled system reboot.
