beagle
- Jun 15, 2020
Anyone having problems creating VMs when running SCALE virtualised?
I installed the latest SCALE nightly virtualised on a VM running on a XCP-ng host. (TrueNAS-SCALE-20.12-MASTER-20201209-072916)
VM specs: 4cores, 16GB RAM, 30GB disk and 1 NIC, nested virtualisation enabled.
On SCALE I've successfully created:
(1) a bridge (br0) with a fixed IP on the single NIC
(2) a RAIDZ2 pool based on 6 x 10GB virtual disks (30GB available)
(3) a ISO dataset to upload installation media
Then with the base system working I tried to create a Linux VM using mostly the default options:
(1) changed Boot Method to
(2) unticked
(3) set Memory Size to 2GB
(4) set Disk Type to
(5) set Network Adapter Type to
(6) on Installation Media I uploaded an installation ISO to the ISO dataset
The VM is created but it doesn't show on the Virtual Machines page. After moving to another page and back, the VM shows on the list.
I can start the VM and connect to VNC. The installation media loads and the initial installation screen does show up but as soon as I select an installation option SCALE reboots. I tried with a CentOS 7 and an Arch installation media with the same results.
I'll probably need to open a ticket on Jira for further investigation but since I'm new to TrueNAS I was wondering if I'm missing an obvious step somewhere.
Thank you for reading this far and for your help.
Cheers
Legacy Bios(2) unticked
Start on Boot(3) set Memory Size to 2GB
VirtIO, location to the only pool tank and size to 10GB(5) set Network Adapter Type to
VirtIO and attached it to the bridge br0(6) on Installation Media I uploaded an installation ISO to the ISO dataset
Cheers
