- Aug 16, 2011
I guess I don't "need" all the space in a single pool, but that's the scenario ZFS is designed for, and it's certainly convenient. Otherwise, I have to create a new pool, then decide what I'm going to move there and what I'm going to keep on the original pool. Shares will probably need to be moved. Other things may need to be reconfigured. Making separate pools does mitigate the risk of a vdev failing and taking the pool with it; I'm figuring that a properly designed, properly maintained six-disk RAIDZ2 vdev isn't very likely to fail. But really, multi-vdev pools are pretty common. Four disks in striped mirrors? That's two vdevs--two, two-disk mirrors, striped together. That's pretty much what @NetSoerfer is suggesting. Advantage is that you can add a pair of drives at a time, rather than groups of four or six. Disadvantage is that the redundancy isn't quite as good (if the wrong two disks go at the same time, you're toast), and you lose half your space to redundancy.
