SAS controller
adam23450
Which SAS controller do you recommend? I have to connect 9 hard drives. Preferably one for $ 120
HoneyBadger
actually does care
Administrator
Any LSI HBA, notably not a "RAID card" should be fine, since you're using HDDs even the SAS2008-based cards like the PERC H200 or others will be fine. Look for a used-pull from a reliable refurbisher and you'll be way under that $120 mark; avoid the "new" cards being drop-shipped from overseas as they're often not genuine and might have QA/QC issues.
The most commonly used controllers have 8 ports (as 2x4-lane SFF connector) so you'll either need a chassis with a SAS expander, or just hook one drive to a SATA port (if you're using SATA drives) - you can buy a 16-port version but they demand a significant price premium.
adam23450
In total, I thought that I would only connect 5 disks to the SAS controller because I still have 4 SATA inputs on the motherboard. I found 2 cards (probably the same). Link below
Would it be appropriate? Better new or used. The used one has a 12-month warranty and the new 36-month warranty
adam23450
Yes, those are the same card. If there is not a big difference in price, the new one will give you some peace-of-mind with the warranty (or at least the ability to return the card if it fails)
So everything will work on this card. Can I connect SATA drives normally?
HoneyBadger
actually does care
Administrator
Yes; you will need to obtain and use a "forward breakout cable" to convert one of the SFF-8087 SAS ports into four individual connectors for the drives, unless you have a hot-swap enclosure or other internal backplane in your system that will handle these duties for you.
You'll also want to look at the threads regarding "crossflashing" the official LSI IT firmware to these cards; out of the box, they typically come with Dell firmware that has some unneeded RAID functionality. Flashing it to LSI firmware allows it to behave exactly like the more expensive LSI 9211-8i cards.
adam23450
Can I convert both ports to connections with SATA drives? Is crossflashing a difficult operation?
HoneyBadger
actually does care
Administrator
Yes, SAS controllers support SATA drives natively - the "conversion" is entirely based on the cable you're using.
Crossflashing is not difficult, it just requires following directions and performing the reboots at the correct time. I've used this guide in the past:
Although notably it doesn't include the steps to flash the BIOS for boot-time troubleshooting, or the ability to boot from drives attached to the H200. If this isn't an issue (you'll boot from USB or SATA) then it's moot, otherwise I'll have to find the commands (and possibly the BIOS file) needed to let it do that.
adam23450
Does such a card require additional cooling?
HoneyBadger
actually does care
Administrator
In a traditional consumer tower-style chassis that was never intended to have a high-heat card like that - yes, you'll want to look at a way of providing some additional airflow. A fan mounted on the top of the PCI bracket area is generally well-received here; screwing a 40mm fan to the heatsink itself less so. Reports are that the H310 runs a lot cooler than the H200 as well, so that may be worth considering.
In a rackmount chassis, there's typically enough airflow being rammed through by those louder/faster fans that those measures aren't necessary. A tower-style server that's designed to have an HBA installed may be able to handle it as well given enough fans in-line.
adam23450
Will the Dell Perc H310, DELL PERC H200 controller support SSDs and HDDs with a capacity greater than 2TB? I need 8TB HDD support and about 3TB SSD
adam23450
Greater than 2TB definitely - but watch out for 4K native size drives ("4Kn") as I've read that it's both supported and unsupported, and don't have a 4Kn drive right now to test.
Do you think the Dell Perc H310 card will support ironwolf 1TB, 2TB, 4TB, 6TB, 8TB, 10TB (regular and pro versions)?
The same will damage the WD Red drive?
HoneyBadger
actually does care
Administrator
IronWolf drives are still 512e drives as far as I know, and will work fine. None of them are the "shingled" or "SMR" type that is a problem with certain WD Red drives - if you do purchase WD Red, make sure to opt for "Red+" or "Pro" - or use the list of SMR drives provided by iXsystems.
adam23450
I flashed my sas card but I don't see the possibility to enter the raid edition. Should it be like that? Previously it was a ctr + r configuration, now I can't see it. The diode on the card is flashing and no devices are connected to the card.
I used this guide (photo) because the one you sent me didn't work. I do not know why :(
Files: https://forums.unraid.net/topic/12114-lsi-controller-fw-updates-irit-modes/page/65/
Steps:
https://forums.unraid.net/topic/12114-lsi-controller-fw-updates-irit-modes/page/34/?tab=comments#comment-403777
The second time I was able to upload the software from the guide. But I still can't get into raid creation etc.
ThreeDee
..the card is just there to connect your drives .. any "raid creation" needs to be done in TrueNAS/FreeNAS
adam23450
@HoneyBadger When I turn off my server with the Dell Perc H310 card, you can hear the disk "shoot" from the head - this is my impression. While they are connected to Sata on the motherboard there is no such sound. What could be the problem?
HoneyBadger
actually does care
Administrator
It could be a difference in how the HBA sends the shutdown command (maybe manually parking the drive heads as opposed to SATA which just lets the drive do it on its own time) - are they being fed power in a different manner (backplane vs. breakout cable) maybe?
While you're looking at your power, make sure you don't have any cheap injection-moulded Molex-to-SATA splitters hanging around.
adam23450
I have no cheap replacements. The adapter is only used for the fan controller. The drive is powered directly from the power supply. Can such "shooting" of the disk head damage it?
If the LED on the card is blinking approximately every 1 second, is it a good sign?
