Hi All,
I am currently running a ASRock C2750D4I with 32 GB of ecc memory. It has 10 4TB hdd with raidz2 configuration and 1 500gb ssd for L2ARC cache. I am planning to move the system to a different system that I own.
System 2 (potential move)
ASrock EPC602D8A with 64 GB of ecc memory. same configuration for storage.
The C2750D4I has 12 sata ports but EPC602D8A has only 6 sata port and it also has an SCU connector where you can connect sas/sata drive.
My question is SCU connector on EPC602D8A is a HBA or it has its own raid controller another words would freenas have direct access to the drives if I attach the extra 4 drives with SAS to SATA forward breakout cable. Does it require any firmware change to the raid controller before it can work?
I realize that with the move I would loose my cache but just wanted to see if it was possible move. I am currently running ESXi on EPC602D8A which I may move to a AMD FX8350 with either ESXi or Citrix (XCP-NG).
Thanks in advance.
Thanks in advance.
