sas controller raid or hba and proxmox or freenas?
gjerdet92
Newbie
I am a bit stuck here trying to decide, I'm just stuck between 2 stones.
i have a hp proliant dl380 g7 server i will use but since it has so much power i will run everything on it. But here it starts :-(
should i run it on raid or to hba mode?
since i need vm, should I run proxmox with raid, or hba to create a zfs pool. And run freenas in a vm.
Or is it better to run freenas with hba and create vm in freenas, freenas and raid is not the best solution?
or should i build another type of freenas server with sata controller instead?
John Doe
Senior Member
you will want to have esxi/ proxmox with an HBA (raid adapter flashed in IT-mode).
connect the discs, that freenas shall use to that adapter.
boot for esxi and freenas shall be a drive not connected to the HBA
