Rtorrent jail/docker
wonderfall/rtorrent-flood
It's a little old, but has lots of stars and aver 1M pulls.
You need to follow the steps in the manual to setup your docker VM, then you can go into that VM and do as you suggest. (section 14.5 in the guide, top right in the old UI)
You will need to learn a bit about how docker and storage works in FreeNAS 11 (NFS share to the VM, then mapping that into the docker container as part of the docker run statement).
