kroko
- Mar 9, 2015
FreeNAS 9.10.2-U1
Currently I do (did) offsite backups from FreeNAS using rsync over SSH.
I have set it up via cron (to execute a script) not rsync tasks. This is because scripting gives stuff that is not available in rsync tasks GUI anyways, like remote deletion backups shuffling (old habit, pratically unneeded if local snapshotting exists), custom SSH private key just for this backup, mailing on error or success, a.o.
However, now I have a bit new setup both SW and HW.
On SW side I am preperaing that Corral upgrade and requestioning my own historical decisions globally in FreeNAS, restructurising, making changes needed (starting to rework flags, namely, --archive, because till now I had unix permissions everywhere, but on preparing soon-to-come-yet-try-again-migration-to-Corral-that-broke-my-smb-on-first-try:) I have already ACL'ed all needed datasets, set non-trivail stuff). Offt.
HW has changed:
- The offsite backup is now self managed Qnap TS-653A hidden in dark woods, not "existing service that we can only SSH into"
- This offsite box will be 24/7 OpenVPN'ed within the DMZ where FreeNAS is located
Thus I do not need rsync over SSH any more, as the traffic to the offsite Qnap is already in 24/7 VPN tunnel and in (V)LAN I do not need encryption. Daemon?
In FreeNAS I enabled rsync service, no tasks.
In Qnap Backup Station > Rsync Server enabled the service and set some test username offsitersyncduser and pw.
Creted 1000x1MB, 200x5MB, 50x100MB files. Tested in dummy 1GbE LAN w/o activity.
Rsync daemon (without SSH)
First sync
Destionation is empty
Second sync
No data changed on Freenas
Third sync
All thousand 1MB files on Freenas now have appended "bleh" bytes, thus all those files are modified
All 5MB files deleted (so --delete also kicks in)
Good ol rsync over SSH
First sync
multiple kex protocol errors: type 7 seq ..., due to not using -x dlag to turn X forwarding off, whatever.
Second sync
Third sync
The first sync gains considerbaly.
But third is dead on (SSH is even faster in bytes/sec, total execution was faster)
So I can go with daemon method.
But can it be made even better, so that "third case" would show benefits of dropping ssh overhead? I have used rsync many times over years for different purposes, but i never have used daemon so - any tips & tricks?
I kow of --skip-compress, --numeric-ds, but those do not apply to this test (would affect both SSH and daemon). SSH cipher hacks are also not relevant, as I am looking if there is way to make daemon faster, not SSH. Maybe I'm just hitting CPU max capability in both cases, so that's it (first daemon sync is ~35 MB/sec).
The interest is only in speed, not how much CPU is used during backup - he should do its job :)
Thanks!
FreeNAS 9.10.2-U1
HW has changed:
time /usr/local/bin/rsync \
--verbose --recursive --archive --compress --protect-args \
--exclude-from=/mnt/vol/offsiteconfigs/offsite-rsyncexclude-master \
--delete --delete-excluded --force --ignore-errors \
--backup --backup-dir="deletebackups-$(date +%Y-%m-%d)-$(date +%s)" \
--password-file=/mnt/vol/offsiteconfigs/.rsyncdpassoffsite \
/mnt/vol/offsitebackuptestfiles/ \
rsync://offsitersyncduser@192.168.48.160:/rsyncfromfreenastestFirst sync
sent 7,344,283,608 bytes received 23,865 bytes 34,724,858.03 bytes/sec total size is 7,340,032,320 speedup is 1.00 real 3m30.385s user 3m25.080s sys 0m2.845s
Second sync
sending incremental file list sent 28,767 bytes received 21 bytes 57,576.00 bytes/sec total size is 7,340,032,320 speedup is 254,968.47 real 0m0.207s user 0m0.005s sys 0m0.013s
Third sync
sent 69,070 bytes received 6,175,948 bytes 462,593.93 bytes/sec total size is 6,291,461,320 speedup is 1,007.44 real 0m12.761s user 0m11.310s sys 0m0.195s
-e "/usr/bin/ssh -p 22 -i /mnt/vol/offsiteconfigs/id_rsa-offsitebackup -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null" \
admin@192.168.48.160:/share/CACHEDEV1_DATA/rsyncfromfreenastestFirst sync
sent 7,344,283,584 bytes received 23,873 bytes 31,453,136.86 bytes/sec total size is 7,340,032,320 speedup is 1.00 real 3m53.069s user 4m3.190s sys 0m9.821s
Second sync
sending incremental file list sent 28,747 bytes received 21 bytes 19,178.67 bytes/sec total size is 7,340,032,320 speedup is 255,145.73 real 0m0.249s user 0m0.013s sys 0m0.014s
Third sync
sent 70,682 bytes received 6,175,948 bytes 499,730.40 bytes/sec total size is 6,291,461,320 speedup is 1,007.18 real 0m12.217s user 0m11.577s sys 0m0.337s
Thanks!
