Hello All,
I am using freenas 802 and so far I like it. Only I do not have enough knowledge to sort out things myself.
I have tried to use deltacopy and rsync together but nothing gets backed up. Instead I am getting this message that freenas is 'failed to connect'. I am using a freecom router that did not pose any hindrance so far to access freenas box.
If anyone has any ideas on how to fix this please let know.
Thank you.
Oct 8 10:18:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:18:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:20:16 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:20:16 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:22:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:22:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:24:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:24:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:26:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:26:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:28:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:28:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:30:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:30:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:32:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:32:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:34:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:34:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:36:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:36:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:38:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:38:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:40:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:40:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:42:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:42:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:44:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:44:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:46:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:46:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:48:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:48:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:50:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:50:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:52:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:52:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:54:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:54:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:56:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:56:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 10:58:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 10:58:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:00:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:00:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:02:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:02:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:04:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:04:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:06:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:06:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:08:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:08:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:10:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:10:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:12:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:12:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:14:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:14:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:16:16 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:16:16 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:18:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:18:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:20:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:20:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:22:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:22:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:24:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:24:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:26:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:26:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:28:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:28:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:30:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:30:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:32:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:32:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:34:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:34:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:36:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:36:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:38:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:38:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:40:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:40:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:42:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:42:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:44:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:44:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:46:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:46:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:48:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:48:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:50:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:50:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:52:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:52:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:54:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:54:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:56:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:56:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 11:58:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 11:58:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:00:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:00:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:02:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:02:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:04:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:04:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:06:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:06:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:08:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:08:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:10:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:10:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:12:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:12:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:14:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:14:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:16:16 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:16:16 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:18:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:18:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:20:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:20:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:22:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:22:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:24:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:24:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:26:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:26:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:28:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:28:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:30:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:30:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:32:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:32:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:34:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:34:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:36:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:36:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:38:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:38:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:40:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:40:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:42:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:42:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:44:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:44:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:46:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:46:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:48:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:48:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:50:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:50:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:52:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:52:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:54:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:54:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:56:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:56:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 12:58:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 12:58:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:00:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:00:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:02:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:02:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:04:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:04:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:06:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:06:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:08:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:08:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:10:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:10:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:12:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:12:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:14:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:14:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:16:16 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:16:16 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:18:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:18:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:20:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:20:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:22:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:22:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:24:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:24:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:26:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:26:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:28:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:28:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:30:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:30:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:32:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:32:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:34:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:34:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:36:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:36:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:38:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:38:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:40:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:40:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:42:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:42:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:44:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:44:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:46:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:46:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:48:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:48:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:50:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:50:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:52:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:52:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:54:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:54:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:56:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:56:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 13:58:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 13:58:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:00:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:00:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:02:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:02:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:04:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:04:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:06:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:06:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:08:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:08:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:10:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:10:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:12:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:12:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:14:16 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:14:16 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:16:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:16:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:18:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:18:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:20:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:20:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:22:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:22:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:24:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:24:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:26:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:26:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:28:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:28:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:30:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:30:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:32:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:32:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:34:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:34:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:36:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:36:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:38:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:38:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:40:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:40:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:42:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:42:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:44:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:44:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:46:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:46:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:48:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:48:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:50:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:50:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:52:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:52:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:54:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:54:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:56:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:56:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 14:58:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 14:58:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:00:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:00:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:02:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:02:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:04:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:04:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:06:16 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:06:16 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:08:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:08:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:10:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:10:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:12:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:12:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:14:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:14:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:16:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:16:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:18:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:18:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:20:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:20:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:22:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:22:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:22:50 freenas freenas[1693]: Executing: /usr/sbin/service ix-crontab quietstart
Oct 8 15:22:50 freenas freenas[1693]: Executing: /usr/sbin/service cron restart
Oct 8 15:22:50 freenas freenas: Stopping cron.
Oct 8 15:22:50 freenas freenas: Starting cron.
Oct 8 15:23:26 freenas freenas[1693]: Executing: /usr/sbin/service ix-crontab quietstart
Oct 8 15:23:26 freenas freenas[1693]: Executing: /usr/sbin/service cron restart
Oct 8 15:23:26 freenas freenas: Stopping cron.
Oct 8 15:23:26 freenas freenas: Starting cron.
Oct 8 15:24:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:24:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.8]
Oct 8 15:26:15 freenas rsync: rsync: failed to connect to 192.168.1.5 (192.168.1.5): Operation timed out (60)
Oct 8 15:26:15 freenas rsync: rsync error: error in socket IO (code 10) at clientserver.c(122) [sende
Thank you.
