SOLVED rsync error between FreeNAS and QNAP
nogi
I have a MicroServer N54L running FreeNAS-9.2.1.8-RELEASE-x64 (e625626) with 16GB RAM. I used to have a QNAP TS-451 and had rsync working fine between the 2 machines. I recently migrated from the TS-451 to a TS-653 Pro. QNAP migration keeps the configuration intact and the QNAP works as expected.
However, rsync is now broken and I can't work out why. The error in the logs are:
2014/12/02 16:30:02 [76911] rsync error: error starting client-server protocol (code 5) at main.c(1517) [sender=3.0.9]
2014/12/02 16:45:01 [77184] @ERROR: auth failed on module mySQL
2014/12/02 16:45:01 [77184] rsync error: error starting client-server protocol (code 5) at main.c(1517) [sender=3.0.9]
2014/12/02 17:00:00 [77434] @ERROR: auth failed on module mySQL
2014/12/02 17:00:00 [77434] rsync error: error starting client-server protocol (code 5) at main.c(1517) [sender=3.0.9]
I've double checked the password on both machines, even reset it on the QNAP again but still can't rsync??
nogi
Don't think so. I managed to get it all working again though. Re-entered credentials on both, did a few reboots and whatever was causing the issue seems to have gone.
