nogi
- Jul 5, 2011
I've gone through the various threads here and on the QNAP forum and am not having much luck. I have a TS-210 which I want to keep offsite and want to be able to sync my FreeNAS server to it. Doesn't matter what I try, I keep failing at this
Testing on the LAN first to get it working before I test offsite.
IP of QNAP is 192.168.1.14
Rsysnc on QNAP is admin with a password
On the FreeNAS, I created the same username/password combo (also tried another username to admin). I created a RSYNC task on FreeNAS pointing to the IP of the QNAP. For module name I used a test share that I created on the QNAP called nonodocs. I can't see anywhere on the QNAP where I can create a module so assuming that it automatically does this??
Dec 3 14:50:00 KANDOR rsync: Password: @ERROR: auth failed on module nonodocs Dec 3 14:50:00 KANDOR rsync: rsync error: error starting client-server protocol (code 5) at main.c(1516) [sender=3.0.8]
