Rvby1
- Jan 17, 2024
My TrueNAS Scale machine has suddenly started having issues with rsync.
I had a critical error show up about the BIOS time being wrong alongside critical errors about rsync failures, but the BIOS time error stopped appearing after I set the BIOS time to UTC. The rsync errors, however, have continued.
When my machine tries to sync the catalog, I get this error:
I also get an error whenever I try to rsync using an rsync job:
Error: [EFAULT] rsync command returned 255 - UNKNOWN. Check logs for further information.
I've tried to find the logs to see if they elucidate anything, but I can't seem to find a way to do that via the GUI, and I can't figure out how to find them via CLI.
I've confirmed that I can not ping github.com or the IP of the rsync-target on the TrueNAS machine. I can, however, ping other sites--like gitlab.com or google.com. On a machine that is plugged into the same switch and on the same network, I can ping github.com or the IP of the rsync-target without any issues.
Running traceroute on google.com, an address I CAN ping I get this, which seems abnormal:
And the same for github.com, which I CAN NOT ping:
I have tried to change from my default Comcast-nameservers over to something like 1.1.1.1, but the issue persists.
It seems like a lot of folks say this is caused by timezone issues. My BIOS clock is set to the current UTC time, while my TrueNAS machine is set to America/Los_Angelos, which is my current timezone. Is this configuration correct/reasonable?
Anyone have any thoughts on what's going on?
This issue seems very similar to this issue, but I haven't had the luck they had with it stopping...
Failed to sync TRUENAS catalog: [EFAULT] Failed to clone 'https://github.com/truenas/charts.git' repository at '/var/run/middleware/ix-applications/catalogs/github_com_truenas_charts_git_master' destination: [EFAULT] Failed to clone 'https://github.com/truenas/charts.git' repository at '/var/run/middleware/ix-applications/catalogs/github_com_truenas_charts_git_master' destination: Cloning into '/var/run/middleware/ix-applications/catalogs/github_com_truenas_charts_git_master'... fatal: unable to access 'https://github.com/truenas/charts.git/': gnutls_handshake() failed: The TLS connection was non-properly terminated.
traceroute google.com traceroute to google.com (74.125.197.100), 30 hops max, 60 byte packets 1 pk-in-f100.1e100.net (74.125.197.100) 6.277 ms 6.379 ms 6.317 ms
traceroute github.com traceroute to github.com (140.82.114.3), 30 hops max, 60 byte packets 1 lb-140-82-114-3-iad.github.com (140.82.114.3) 7.268 ms 7.179 ms 7.137 ms
SOLVED - Cannot load any catalog due to TLS error ?
Hello I've been having an issue where I simply cannot have any catalog show up on one of my servers (Charlie) with this error: Failed to sync OFFICIAL catalog: [EFAULT] Failed to clone 'https://github.com/truenas/charts.git' repository at '/mnt/Storage1...
www.truenas.com
