rvassar
- May 2, 2018
I've been mostly happy with FreeNAS 11u5 on my little Dell Optiplex 790. But as I related to @Chris Moore, as I make greater use of it, it's become obvious I'm doing another build at some point. The major issues are:
1 - Non-Server grade hardware. No ECC, no IPMI, lack of disk expansion options, PCIe lanes bundled uselessly in x4 & x16 slots.
2 - Lack of CPU/Memory capacity to support jails & VM's, larger ZFS pools.
3 - USB boot devices, which have now bitten me repeatedly.
With that in mind I started poking around with the idea of picking up a 2+U rackmount server of recent vintage. Something with at least 6 - 8 DDR3 slots, and 12 drive bays. But my original motivation for the Optiplex chassis was to keep the noise & heat down. Moving to a rack server would require me to address noise & power density issues. Some of my thinking has been summed up in the home racks discussion here:
https://forums.freenas.org/index.php?threads/19-racks-for-home.64450/
and I am still pursuing constructing some kind of office rack with an eye for noise management. I need to find out how much power & cooling capacity I actually have here in the home office, and just how how much air I need to move to keep things cool.
There's nothing like a good experiment!
With that in mind, I decided to revert to the old system I keep around for test purposes, the machine I initially evaluated FreeNAS on. An 11 year old Dell SC1430... I installed a second X5355 CPU bringing it to 8 cores and 240 watts TDP, a SAS HBA to get modern SATA speeds and a small SSD boot device, it already had 16Gb of ECC memory (ddr2).
So far my office is roughly 1.5 deg/C hotter, and I'm pulling almost 100 watts more power, so it costs 20 cents a day more to run. I am actually wondering if I really need the second socket occupied or not. On the noise front, it is louder, but tolerable. I did place it in the tower cabinet in my desk, but I have to keep the door propped open to keep the drive temps down (smartctl is reporting 39 - 43/C). If I close the cabinet door, the fans spin up a little bit and negates any sound dampening benefit, and the drives warm up to 46/C. I'm guessing I need at least a 2 x 120mm fans to keep this in check in a fully enclosed cabinet.
