Reverse Rsync with deltacopy
doglover
Member
I read with interest the thread:
http://forums.freenas.org/showthrea...dline-push-to-Windows-7-DeltaCopy-Server-pull
since I am trying to do the same thing. I want to move all my files off my windows XP box onto the FreeNAS server and then use my windows box as the rsync backup server for the FreeNAS rsync client.
Actually I can get it to transfer the files just fine but then I can't view the files on my windows box. The deltacopy FAQ does discuss this problem with the windows user not having rights to view the files. The FAQ says to configure the windows server to login as administrator. I have tried this and it doesn't work. Has anyone else set it up so that you can access the files on the windows deltacopy server side?
Thanks,
IMF
mskenderian
Member
I have the same issue, i figure part of it out, u have to take ownership of the file/folder right click properties. -> security -> advanced-> owner-> edit, then pick ur username then apply and ok, close all of it, u may have to go back to properties find ur security, find ur username and click on full control.
My issue is i can see the files now, i cant delete them.
