Hello colleagues.
I read with interest the thread:
http://forums.freenas.org/showthrea...dline-push-to-Windows-7-DeltaCopy-Server-pull
since I am trying to do the same thing. I want to move all my files off my windows XP box onto the FreeNAS server and then use my windows box as the rsync backup server for the FreeNAS rsync client.
Actually I can get it to transfer the files just fine but then I can't view the files on my windows box. The deltacopy FAQ does discuss this problem with the windows user not having rights to view the files. The FAQ says to configure the windows server to login as administrator. I have tried this and it doesn't work. Has anyone else set it up so that you can access the files on the windows deltacopy server side?
Thanks,
IMF
Thanks,
IMF
