Hey all. How do I go about wiping my flash drive back to normal So I can use it again? I used it to install freenas on my satadom so I no longer need the installer. Thanks all!
Should be as simple as inserting it into a regular desktop PC, cleaning the partition table, and reformatting. Under Windows, this might necessitate something like the "Disk Management" applet or dropping to a command line and using diskpart.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
