MacGulliver
- Mar 24, 2015
Hi everyone,
i'm a long time reader, but this is my first post. First of all let me thank all of you, this is a great community.
Introduction:
i build my system in Oct. 2014 with only 2x3TB in Mirror for budget reasons. two weeks ago i upgraded with 3x3TB to a 5 drive raidZ2 Pool. To accomplish that i backed up my data via zfs send/recv to an eSATA drive, destroyed the mirror, build the raidZ2 and restored my data via send/recv. All went well as i can access my Data and even continue my TimeMachine Backup where i left it.
The Problem:
my plugins won't show up in GUI, but the corresponding jails were under the Jails section although i can't access a single one's WEB frontend or get any livesign at all.
I had several Plugins installed through the GUI (Sabnzbd...) and i although made two simple Jails not including a preconfigured Plugin. The custom Jails are functioning as before but the plugins won't show up.
What i tried so far:
what i was hoping to do:
just like the User "panz" pointed out a while back in this Thread: https://forums.freenas.org/index.php?threads/rebuild-pool-jails-config-question.21695/
i'd like to install a plugin to get it back in the GUI and after that restore the content of the Jail from my backup eSATA HDD.
But here is where i got stuck for the last 2 Days, i don't understand how i would accomplish that.
i'm not afraid of using the command line but completely new to BSD, ZFS and all the goodness, so could you please point me in the right direction?
thanks a lot
Introduction:
The Problem:
- checked the plugins location which is set correctly to the new pool (as i named it equal to my previous mirror) rebooted a couple of times -> no plugins.
- deleted the jails and tried to restore with but now even the jails section is empty.Code:
zfs send -R backup/jails/sabnzbd_1@tobackup | zfs recv mymirror/jails/sabnzbd_1
- tried to install the Plugin first (worked fine) an send/recv from backup which told me something like
sorry can't remember the full message.the snapshot your sending is older than the destination - tried to reinstall the plugin through GUI which responded
because i restored the jail prior to reinstallationwarden: ERROR: A jail with this name already exists!
thanks a lot
