Hello. I have a small server running FreeNAS and for backups since I don't have another machine to replicate to, I do manual incremental zfs send to a big Usb drive once a month. On my machine I have 2 pools, both encrypted. One is running on HDDs and serves mostly media files, computer/phone backups etc, and the second one is running on SSDs and has Plugins, Jails and VMs.
While doing the manual incremental backup to the usb drive (via cli), the HDD pool gets updated normally. This is not the case with the SSD pool though, which fails every time I try to do incremental backups and for several months I have not found any solution so I have to delete the previous backed up and zfs send the pool from scratch.
The error I'm getting is:
My suspicion is that since iocage (jails and plugins) are on that pool, they get modified all the time so between the time i make the snapshot and try to zfs send it, there are modifications. I have tried turning off all of my running jails and plugins but I keep getting the same error.
I'm also baffled with the "destionation <...> has been modified" part of the error. How is that possible? The backup pool is imported on freenas UI so that it can get decrypted etc prior to the replication attempt, although it's jails/plugins/vms should not be running, and they are not shown in the freenas UI as being so...
Have anyone had the same issue? And is there a way to overcome it? I have seen the -F flag that forces a rollback in the sender's side but I'm afraid it might mess with the jails or freenas itself in an irreversible way...
Thank you
cannot receive incremental stream: destination <...> has been modified since most recent snapshot warning: cannot send '<...>': signal received
Thank you
