Manual ZFS send and receive
webdawg
I am trying to do a manual send and receive between two boxes via command line. I usually do an initial ZFS send and then send incremental after that.
After I send the initial stream I set the filesystem to read only on the destination.
But when I send the incremental I get:
cannot receive incremental stream: destination eh/data has been modified
since most recent snapshot
The send box is OpenIndiana and receive is FreeNAS.
emk2203
Isn't the setting to read-only the modification in question? Or in other words, what happens when you don't set the destination to r/o?
wblock
Documentation Engineer
If you want it read-only (not required), create an empty dataset to receive the snapshots before sending, then set that to read-only. How current is the OpenIndiana system? Recent?
webdawg
The OI system is fairly recent. It is hipster but it needs updated.
I just did as you mentioned, set read only first, I will let it go and see what results tommorow.
My plan is to move everything over to FreeNAS and I have been told by a FreeNAS expert that a send and receive between these systems will work, but I plan on checking the data after transfer just in case.
In the past I set readonly after and did not have an issue, I wonder what the problem is.
PhilipS
Something must have changed on the receive side (atime on a file perhaps?) - you could perform a zfs diff if you want to find out. If you don't care and you just want the incremental snapshot to send, then add a -F on the zfs receive which will force a rollback.
