Stripped when I meant to mirror
Rusky
I have my jail running off of a ssd
I just installed a second ssd with the intention of running them in a mirror in case one failed. I clicked through the volume manager too quickly and selected strip instead of mirror.
Anyway to undo this? Ultimately I just want to mirror the jail between both SSDs
If it helps I have a snapshot of the jail
UPDATE:
I got it fixed thanks to this thread
https://forums.freenas.org/index.ph...to-move-my-plugin-jail-to-another-pool.32906/
I attached a 3rd SSD and created a new volume then did the below steps
Assumptions:
The pool you are transferring the jails from is main_pool
The destination pool is ssd_pool
The jail root (Jails->Configuration) is /mnt/main_pool/jails
The new jail root will be /mnt/ssd_pool/jails
Steps:
Turn off all plugins (Plugins->Installed)
Stop all jails (Jails->View Jails)
Run these commands via CLI:[PANEL]zfs snapshot -r main_pool/jails@relocate
zfs send -R main_pool/jails@relocate | zfs receive -v ssd_pool/jails
zfs get -rH -o name -s received mountpoint ssd_pool/jails | xargs -I {} sh -c "zfs set mountpoint=/{} {}; zfs mount {};"[/PANEL]
Change the Jail Root to /mnt/ssd_pool/jails (Jails->Configuration)
Start jails/plugins
Check that everything works and destroy the original jails dataset (main_pool/jails)
Once I confirmed the jail was up and running on the new SSD, I destroyed the old volume and rebuilt it in a mirror.
Then I reversed the steps to move it from the new SSD back onto the mirrored volume
sfcredfox
I'm pretty sure there are some posts that say you're rebuilding your pool if you misconfigure a vdev. I haven't seen anything talking about the ability to reconfigure then.
I can't really say how you'd transfer the files between pools, but I have copied a dataset between pools with zfs send/receive I think, been a while.
You could probably copy the dataset for the jails to another pools, recreate your SSD pool, then transfer back.
Someone else might need to back this up though
kdragon75
You would need a third disk. Or you could use send and receive to backup to another pc then destroy the pool and rebuild/restore.
@sfcredfox better said than me. But yeah if you have another pool and the space you can just "move" the dataset over and back.
sfcredfox
I can't say if those instructions work or not, but I'd make a backup just in case, and then trying it is your call. I'd be interested to know if you can replicate their success though
Rusky
I'll make a backup of the jail and try converting it into a mirror
But if I'm understanding what you said correctly
- Stop my plugins
- Copy the contents of my jail that's on the striped SSDs onto a 3rd SSD
- Wipe the volume the jail is one
- Properly setup the original 2 SSDs in mirror
- Copy the files off the 3rd SSD into the new mirror
- Start plugins
MrToddsFriends
Documentation Browser
Remember that in ZFS terminology a single disk is called a stripe, too. The issue report and the guidance you posted are about converting a single disk vdev to a mirror vdev. AFAICT, converting a two-disk stripe into a two-way mirror indeed involves backing up and creating a new pool from scratch.
Rusky
Alright guys I did it, had to move it off and back
For anyone who stumbles across this thread in the distant future I'll update my original post with the steps
