I have just upgraded my two HP Gen8 Microservers from 11.3 to 12.0. All jails and also the PiHole-VM work perfectly. Fine!
But I have a big problem with some replication tasks:
hourly snapshot from the dataset zroot/xyz ----> zroot-backup/xyz (holding time: 24 hours) works fine.
If I configure another replication task
daily snapshot from the dataset zroot/xyz ----> zroot-backup/xyz (holding time 2 weeks)
The snapshot is created, but the transfer to the backup-system fails with the following error message:
Replication "daily - zroot/xyz - zroot-backup/xyz" failed: No incremental base on dataset 'zroot/xyz' and replication from scratch is not allowed .
Where is the problem??
EDIT:
/var/log/zettarepl.log:
[replication_task__task_5] [zettarepl.replication.run] For task 'task_5' non-recoverable replication error NoIncrementalBaseReplicationError("No incremental base on dataset 'home/xyz' and replication from scratch is not allowed")
defcon999
EDIT:
defcon999
