i've been running an hp mediasmart server for about 10 years. it has windows home server on it; the 2007 version, not even vail/2011 version. the limitations of that os have been evident for a while. like i'm limited to a 0.9 version of plex and have to run plex classic on my roku. it's starting to run out of space, so rather than add another drive, i'd like to replace it with a freenas server. i think i got my money's worth out of it anyway.
i'd like to have around 10TB of storage. the server will be used to backup my windows computers and run jails for:
- plex media server.
- minimal transcoding. 99.9% of my streaming is to a roku 3 and i make sure to use movie files that can be direct played. if any transcoding is to happen, it will be content streamed from a plex channel.
- transmission (i might add openvpn + pia. i need look into this more.)
- logitech squeezebox server.
- CPU:
Intel Core i3-6300Intel Core i3-7320- update 6/20/18: no good reason except for 7320 > 6300. :D
- Motherboard: Supermicro - MBD-X11SSM-F-O Micro ATX LGA1151 Motherboard
- Memory:
Crucial - 16GB (1 x 16GB) DDR4-2133 ECC Memory (CT16G4WFD8213 / MTA18ASF2G72AZ-2G1A1)Crucial - 16GB (1 x 16GB) DDR4-2400 ECC Memory (CT16G4WFD824A)- update 6/20/18: faster and found it for cheaper than the comparable 2133MHz part.
- Boot Drive:
SanDisk - SSD PLUS 120GB 2.5" Solid State DriveKingston A400 120GB 2.5" Solid State Drive- update 6/20/18: cheaper.
- Storage: 6 *
Western Digital - Red 4TB 3.5" 5400RPM Internal Hard DriveWestern Digital - Red 2TB 3.5" 5400RPM Internal Hard Drive- update 6/20/18: 6 * 4TB would have been way more space than i need. i would likely upgrade or the drives would fail before i filled them up.
- raidz2.
- Case:
Fractal Design - Define R5 (Black) ATX Mid Tower Caseor Fractal Design - Node 804 (Black) MicroATX Cube Case- update 6/20/18: node 804 cases were unavailable for a while. the r5 was a backup.
- Power Supply: SeaSonic - 650W 80+ Gold Certified Semi-Modular ATX Power Supply
- Cables: Left angle and right angle sata cables.
- update 6/20/18: for the drives over the power supply.
