SOLVED replacing components
Theapplefuture
Hallo everybody,
first I'm not 100% sure if this topic belongs here, so correct me if I'm wrong.
My question is about the replacement of specific components.
I don't want a manual but only a short information for two cases.
Case 1 - A HDD fails :
If a HDD fails, can I just replace it with a new one and all data (RAID-Z2 Configuration) will automactilcay be restored on my HDD ?
Case 2 - CPU / RAM / Motherboard fails :
I think I would be able to find out what component fails, BUT the question is, can I simply replace the component which fails and the system continues to run ?
For example if the motherboard AND CPU fails, can I simply buy a new CPU and a new Mainboard and plug everything in and the system runs as if nothing happens or can it be that I need to do more than just that ?
And what if the USB drive on which my OS is stored and booted from fails, are my personal files in danger or is this no problem ?
Bidule0hm
Server Electronics Sorcerer
Yes. But you must follow the procedure, don't just pull the bad drive and put the new drive in.
Yes.
And what if the USB drive on which my OS is stored and booted from fails, are my personal files in danger ?
No. Just reinstall to a new drive and upload your saved config (so remember to save the config...), that's all. NB: I recommend a SSD, far better than USB sticks (even a mirror of them).
Chris Moore
Case 1. It is manually initiated.
