manslipkorn
- Jan 29, 2020
Hello everybody, this is my first message here but I've been using FreeNAS for quite a long time now (around 9 years).
Good sign, 9 years without a post on these forums, that means I'm very happy with FreeNAS (or never had problem with it).
Anyway, I'm coming up here for a hardware problem, and though you might be able to help me out.
As many NAS builders, I bought an ASRock motherboard C2550D4I three and a half years ago and have been lucky up to now (lots of messages here about issues with this motherboard with faulty BMC and Atom Cxxx issues).
But, unfortunately, this motherboard died yesterday (no post, no display, just IPMI working via BMC and nothing else). I think this is related to the issue with Atom Cxxx every one is talking about. And of course, the warranty expired few months ago.
As a result, I'm now left with :
- 16 Gb DDR3 ECC ram
- power supply
- 5 hard drives
- 3U case
With that hardware being perfectly fine and working, I would like to buy the minimum I need to run FreeNAS again wich is a motherboard and a processor.
My problem is that every motherboard being sold at the moment requires DDR4 ram (and ECC DDR4 ram motherboard and ECC DDR4 ram is very expensive). Also, I don't want to f*** the planet even more, my DDR3 ECC ram is fine, there is no need to throw it away.
So basically, I'm looking for a motherboard/processor, not too expensive that fits my needs which are :
- 5 SATA III 6Gbit/s ports minimum (8 would be good as I have few SSD too for VMs and cache)
- DDR3 ECC compatible RAM
- low power consumption
- IPMI if possible as it's very convenient (if not, I'll just connect a VGA screen to it)
Have you got any suggestions for these kind of hardware? Can I still find something similar today without going full DDR4 ECC?
Thanks a lot in advance for your help on this topic, you would save me some money and help planet earth for reusing perfectly fine hardware.
- power supply
- 5 hard drives
- 3U case
