Replaced bad drive, pool is still degraded
john tilocca
i am running version FreeNAS-9.10.2-U6 (561f0d7a1) with 32 gig ecc ram
I just replaced a bad drive and it finished resilvering and now it gave me this
any ideas ?
[root@BigBox ~]# zpool status -x
  pool: data
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
	   the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: resilvered 630G in 13h16m with 0 errors on Sun Sep  2 05:18:26 2018
	   NAME											STATE	 READ WRITE CKSUM
	   data											DEGRADED	 0	 0	 0
		 raidz2-0									  DEGRADED	 0	 0	 0
		   gptid/dd44c93f-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/de25d881-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/688c7fc4-4a19-11e7-acad-003048b89c56  ONLINE	   0	 0	 0
		   gptid/e27f3c49-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/e3573ab9-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/e44182cd-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/e52411d6-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/e62bc67c-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/e71a1ea3-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/ece6788b-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/edcb2da5-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/eea8f53f-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/efc87310-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/e52c513c-4f70-11e7-a75b-003048b89c56  ONLINE	   0	 0	 0
		   gptid/f18483c8-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   gptid/f25dd5cf-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
		   10865396165262864836						UNAVAIL	  0	 0	 0  was /dev/gptid/f6e9b383-c12c-11e6-949f-003048b89
c56
		   gptid/e5afd574-ae21-11e8-b6df-003048b89c56  ONLINE	   0	 0	 0
		   gptid/f8c69033-c12c-11e6-949f-003048b89c56  ONLINE	   0	 0	 0
errors: No known data errors
[root@BigBox ~]# zpool list
NAME		   SIZE  ALLOC   FREE  EXPANDSZ   FRAG	CAP  DEDUP  HEALTH  ALTROOT
data		  17.1T  11.7T  5.43T		 -	37%	68%  1.00x  DEGRADED  /mnt
freenas-boot   464G  4.77G   459G		 -	  -	 1%  1.00x  ONLINE  -
Jailer
Not strong, but bad
19 drive wide vdev? :eek:
Please use code tags when posting terminal output.
Are you sure you replaced the correct drive?
kdragon75
Did you test the NEW drive BEFORE replacing the old drive?
Jailer
Not strong, but bad
Well if you are sure you replaced the correct drive then it looks like you have another dead drive. Identify what drive it is and see if you can get some smart info from it. You are running smart tests correct?
