Multipath not showing up 9.10
Running: FreeNAS-9.10.2-U2 (e1497f2)
I had 2 drives failed over the long weekend. I put in new drives, ran /usr/local/bin/midclt call notifier.multipath_sync. It returned "null". When I go to replace either failed disk I do not get multipath drives, only da.
Any advice?
Here is my zpool status output:
  pool: data
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
	Sufficient replicas exist for the pool to continue functioning in a
	degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
	repaired.
  scan: resilvered 1.16T in 6h11m with 0 errors on Thu Aug 31 17:13:56 2017
	NAME											STATE	 READ WRITE CKSUM
	data											DEGRADED	 0	 0	 0
	 raidz2-0									  ONLINE	   0	 0	 0
	   gptid/89a27cbf-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8a31a03d-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8acc4c5f-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8b5ca435-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8bed792a-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/a7249b09-3c34-11e7-a870-002590c7ed2a  ONLINE	   0	 0	 0
	 raidz2-1									  ONLINE	   0	 0	 0
	   gptid/8d1beee4-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8daa3fc3-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8e3d7782-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8ed13c39-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/8f686f4f-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9001d67b-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	 raidz2-2									  DEGRADED	 0	 0	 0
	   gptid/90a4ac68-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/913f3615-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/91d39ddd-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9274059a-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/930de7ee-ea85-11e6-a3d5-002590c7ed2a  FAULTED	  0	60	 0  too many errors
	   gptid/93af18d7-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	 raidz2-3									  DEGRADED	 0	 0	 0
	   16174481626952339097						UNAVAIL	  0	 0	 0  was /dev/gptid/7948abfd-8e76-11e7-b01d-002590c7ed2a
	   gptid/94f2136d-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/959790eb-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/963ad4f3-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/96d31631-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9767ba0c-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	 raidz2-4									  ONLINE	   0	 0	 0
	   gptid/981b6314-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/98ca85e8-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/996ec779-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9a1b5937-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9ac29453-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9b646841-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	 raidz2-5									  ONLINE	   0	 0	 0
	   gptid/9c26b7d5-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9ccd74ff-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9d7712b4-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9e1d33c2-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9ec66b7d-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
	   gptid/9f6def2b-ea85-11e6-a3d5-002590c7ed2a  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Wed Aug  2 03:45:04 2017
	freenas-boot  ONLINE	   0	 0	 0
	 ada0p2	ONLINE	   0	 0	 0
Who setup the multipath originally?
What version was that?
D
dlavigne
Guest
Do you get the same issue if you update to the latest STABLE (11-U3)?
