It won't hurt to try, but 130 GB seems way too much for it to work. You have 2 GB of swap, which might as well be nothing in this case, plus whatever ZFS left out due to how metaslabs are setup, which I don't think would amount to that much.
I think you need to go back to your vendor and have them replace the disk with something that is the right size or larger.
