mka
- Sep 26, 2013
ATM my FreeNAS server is running 24/7 although I don't need it to be—just because of better ARC performance I let it run continuously. At about 3am the last PC has finished it's backup and the server won't be accessed until about 7pm because nobody is home; during that time I want to safe energy and expect the drives from my pool to power down.
I set the drives to spindown after "30min" via the FreeNAS WebGUI an this has worked initial. But now it won't and I'm fairly certain it's because I recently created the jail location at my main pool.
On that jail is currently only the Plex server as a pbi/plugin running but it is probably write logs and stuff to its system directories keeping the whole pool from spindown. I disabled the timed checks for changed media contents by the PMS as well.
I've 6 Western Digital Red Drives and one spare 64GB SSD. I'm considering to relocate my jail/Plugin path to that drive. Can this been done in a non-destructive way, so the PMS is running and stay compatible in what the WebGUI expects as a jail location? Or could I just stop the server, move to the SSD location and try to edit the paths from the WebGUI?
I don't want to break compatibility with coming FreeNAS version or PBI updates for the Plex Server in particular.
Thank you!
Thank you!
