Stux
- Jun 2, 2016
Stux submitted a new resource:
How to relocate swap to an SSD or other partition - creating a swap device, and replacing pool swap with a Post-Init command
Read more about this resource...
FreeNAS by default will allocate 2GiB on each pool HD and use this as swap. Unfortunately, if a disk fails, your system may crash.
If you have an SSD, or another device/partition for use as swap it can be beneficial to relocate swap to that device.
At the same time it is beneficial to leave the default pool swap where it is because it allows you the ability to replace...
