Ed Furlong
- Dec 21, 2013
I am having some problems with my setup. I pretty sure it's gone but I'm trying everything first to try and get the data back. I'm running hardware RAID0 across 4 hard drives. Before I could get the data on them and backed up, I started having problems accessing the drives. Currently the hardware RAID card is seeing all of the drives and the array is active but my pool is not loading. During boot I get a bunch of errors about bad sectors on one of the drives and I get a "Secondary GPT table is corrupt, using primary."
I've tried gpart recovery but it says recovery is not needed.
Not sure where to go from here. Is there any hope or should I just blow it away and accept that I'm an idiot for using RAID0 without backing the data up properly?
Thanks!
Thanks!
