Good morning one and all.
I am fairly new to this FreeNAS software, so forgive me for being a little green.
I just converted my Windows 2k8 server over to NAS to run a fileshare/PLEX box. So I think I am suffering from gremlins as I might not have done the whole thing “properly”
I am running FreeNAS as bank of Hard drives, basically, its hosting shows and movies I can easily replace or content I don’t care about.
So redundancy is a non issue for me, I am looking for Hard drive space.
This morning, I got an email saying one of my GPT tables is messed up
I am looking for help on how to fix it.
Basically, nothing is backed up, nor will it ever be. So I am happy to move content off the drives and run what ever commands are needed to resolve the issue.
I believe all the drives are working, I ran a S.M.A.R.T scan and no errors reported. (a few months ago)
Is there a simple set of commands I can run to clean it up?
Bellow are the contents of the email I received this morning, I have extrapolated the errors I could see, there may be more, but I would like to tackle them one at at time J
Thanks for your help in advance.
GEOM: ada0: the primary GPT table is corrupt or invalid. GEOM: ada11: the primary GPT table is corrupt or invalid. GEOM: ada2: the primary GPT table is corrupt or invalid. GEOM: ada10: the primary GPT table is corrupt or invalid.
media-pc.local changes in mounted filesystems: 3,4d2 < MEDIA /mnt/MEDIA zfs rw,nfsv4acls 0 0 < MEDIA/media /mnt/MEDIA/media zfs rw,nfsv4acls 0 0 7,8d4 < Storage /mnt/Storage zfs rw,nfsv4acls 0 0 < Storage/storage /mnt/Storage/storage zfs rw,nfsv4acls 0 0 20a17,20 > media /mnt/media zfs rw,nfsv4acls 0 0 > media/media /mnt/media/media zfs rw,nfsv4acls 0 0 > storage /mnt/storage zfs rw,nfsv4acls 0 0 > storage/storage /mnt/storage/storage zfs rw,nfsv4acls 0 0 media-pc.local kernel log messages: > GEOM_ELI: Device mirror/swap3.eli destroyed. > GEOM_MIRROR: Device swap3: provider destroyed. > GEOM_MIRROR: Device swap3 destroyed. > GEOM: ada1: the primary GPT table is corrupt or invalid. > GEOM: ada1: using the secondary instead -- recovery strongly advised. > g_access(918): provider ada1p2 has error 6 set > GEOM: ada2: the primary GPT table is corrupt or invalid. > GEOM: ada2: using the secondary instead -- recovery strongly advised. > GEOM: ada10: the primary GPT table is corrupt or invalid. > GEOM: ada10: using the secondary instead -- recovery strongly advised. > GEOM_MIRROR: Device mirror/swap3 launched (2/2). > GEOM_ELI: Device mirror/swap3.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware > Failed to fully fault in a core file segment at VA 0x817793000 with size 0x4000 to be written at offset 0x5dca000 for process smbd > Failed to fully fault in a core file segment at VA 0x81a056000 with size 0xd000 to be written at offset 0x857e000 for process smbd > Failed to fully fault in a core file segment at VA 0x81a5e9000 with size 0x8000 to be written at offset 0x8907000 for process smbd > pid 32691 (smbd), uid 0: exited on signal 6 (core dumped) > GEOM_ELI: Device mirror/swap4.eli destroyed. > GEOM_MIRROR: Device swap4: provider destroyed. > GEOM_MIRROR: Device swap4 destroyed. > GEOM: ada0: the primary GPT table is corrupt or invalid. > GEOM: ada0: using the secondary instead -- recovery strongly advised. > GEOM: ada11: the primary GPT table is corrupt or invalid. > GEOM: ada11: using the secondary instead -- recovery strongly advised. > GEOM_MIRROR: Device mirror/swap4 launched (2/2). > GEOM_ELI: Device mirror/swap4.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device mirror/swap4.eli destroyed. > GEOM_MIRROR: Device swap4: provider destroyed. > GEOM_MIRROR: Device swap4 destroyed. > GEOM: ada0: the primary GPT table is corrupt or invalid. > GEOM: ada0: using the secondary instead -- recovery strongly advised. > GEOM: ada11: the primary GPT table is corrupt or invalid. > GEOM: ada11: using the secondary instead -- recovery strongly advised. > GEOM_MIRROR: Device mirror/swap4 launched (2/2). > GEOM_ELI: Device mirror/swap4.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device mirror/swap3.eli destroyed. > GEOM_MIRROR: Device swap3: provider destroyed. > GEOM_MIRROR: Device swap3 destroyed. > GEOM: ada1: the primary GPT table is corrupt or invalid. > GEOM: ada1: using the secondary instead -- recovery strongly advised. > GEOM: ada2: the primary GPT table is corrupt or invalid. > GEOM: ada2: using the secondary instead -- recovery strongly advised. > GEOM: ada10: the primary GPT table is corrupt or invalid. > GEOM: ada10: using the secondary instead -- recovery strongly advised. > GEOM_MIRROR: Device mirror/swap3 launched (2/2). > GEOM_ELI: Device mirror/swap3.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware -- End of security output --
