recover zpool from failed drive.
msanger
So I have a raiz1 pool configured with 3 3TB drives, about a month ago ada1 began having issues and failing chksum
root@freenas:/mnt/zfs # zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:10:02 with 0 errors on Fri Nov 13 03:55:02 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
pool: zfs
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub repaired 42.0M in 2 days 23:43:56 with 0 errors on Tue Nov 10 23:44:49 2020
zfs ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/3873cdde-828a-11e4-bde5-842b2bac8a2d ONLINE 0 0 0
gptid/2893e7df-82a2-11e4-858f-842b2bac8a2d ONLINE 0 0 1
gptid/24df54ca-82f4-11e4-aa0e-842b2bac8a2d ONLINE 0 0 0
The system recovered to which I thought I have time and began trying to prepare for a drive replacement, I later found the following status
root@freenas:~ # zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:11:42 with 0 errors on Wed Jan 6 03:56:42 2021
da0p2 ONLINE 0 0 0
pool: zfs
state: DEGRADED
status: One or more devices has been removed by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 119M in 1 days 05:47:11 with 0 errors on Mon Dec 14 05:49:24 2020
zfs DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
13634946646434885157 REMOVED 0 0 0 was /dev/gptid/2893e7df-82a2-11e4-858f-842b2bac8a2d
To which I followed and ordered a replacement drive, once it arrived I followed
https://www.ixsystems.com/documentation/freenas/11.3-U1/storage.html#replacing-a-failed-disk
I offlined the drive, and since i do not have a hot-swappable system I powered down and replaced the drive. To only be greeted by a non functioning zpool this is what I am currently seeing
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 0
root@freenas:~ # zpool list
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
freenas-boot 14.4G 4.00G 10.4G - - - 27% 1.00x ONLINE -
root@freenas:~ # zpool import
pool: zfs
state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
devices and try again.
see: http://illumos.org/msg/ZFS-8000-3C
zfs UNAVAIL insufficient replicas
raidz1-0 UNAVAIL insufficient replicas
3060771620888435127 UNAVAIL cannot open
13634946646434885157 OFFLINE
I am aware of the noobish nature of my question but any help to dig myself out of this mess is appreciated, and I can provide any and all missing infos to help in fixing. prerequisite 5 units will be added to the tab for future enjoyment.
Thank you
msanger
Looking at the status messages closer, it seems that one of the other "good" drives is not being recognized by the system. I will reconnect everything and try again.
Chris Moore
Looks like we are late to the party. I am happy you were able to resolve the issue. Good job troubleshooting. I can't tell you the number of times that reseating the connection fixed a fault. Always worth trying.
Etorix
Good to know you solved the issue.
Note thet it is not necessary to offline a drive to replace it. You can plug the new drive to a free SATA port, go to Pool>Status, and ask to replace the drive while it's still in, so you resilver with full redundancy.
